Page 14 of 30 1 2 12 13 14 15 16 29 30
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055721
04/09/12 11:05 PM
04/09/12 11:05 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Last one. I may start on the grille resto next now that the car is home. Dynamat (placed inconspicuously) and the headliner will be first to be done on the body.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055722
04/10/12 12:02 AM
04/10/12 12:02 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Car looks FANTASTIC! .......No hood scoops?
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: ScottSmith_Harms] #1055723
04/10/12 01:14 AM
04/10/12 01:14 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thanks Scott! Not yet, the holes are there though.
Last week I got my carb back, plus a set of SBP center caps.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055724
04/10/12 01:15 AM
04/10/12 01:15 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Nice! Didn't burn up huh?
*Your choke is under way....
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: ScottSmith_Harms] #1055725
04/10/12 01:20 AM
04/10/12 01:20 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thankfully no. Can't say the same for a 70 6BBL Cuda, a 71 Challenger Vert, NOS shaker bases, Hemi parts, and A LOT of other parts.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055726
04/11/12 07:24 AM
04/11/12 07:24 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Now I can't wait to see the grille
Nice work buddy, I'll want allot of tips from you
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: UCUDANT] #1055727
04/11/12 10:29 PM
04/11/12 10:29 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Best tip I learned from my car, buy Evaporust by the gallon, and get some RPM
I got the driver side vent installed, along with the Dynamat. I was also able to cleane the garage some, and send back an incorrect lower ball joint to Rock Auto. Heres the roof
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055728
04/11/12 10:31 PM
04/11/12 10:31 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Heres the floor. Thats probably all I will do for now. If more is needed than I'll do it after getting it running and driving. Its in the doors and rear panels too, you just can't see it.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055729
04/12/12 10:11 AM
04/12/12 10:11 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Do you have your leaf spring clamps on the wrong way? I'm putting mine back together and noticed yours are on different then mine. I doubt it affects the function of the spring any.
This pic shows the clamps on Dave Waldens Challenger. The rubber insulator is on the top of the spring...not the bottom.
https://board.moparts.org/ubbthreads/upload2/4502617-Dsc05279-1.jpg
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: burdar] #1055730
04/12/12 11:27 AM
04/12/12 11:27 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
After consulting with my memory card, my clamps are/ were both ways originally. The front clamp the rubber is on top and the rubber is on the bottom on the rear clamp. I just replaced them the same way I found them. This is how my spring looked before taking it apart.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055731
04/12/12 12:04 PM
04/12/12 12:04 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I saw your picture and thought "Oh crap" did I just put my clamps on wrong?
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: burdar] #1055732
04/14/12 12:57 AM
04/14/12 12:57 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Today I was able to get some little things done. I installed the dual exhaust bracket, tip hangers, brake hose bracket, pedal assy, dome light wiring, fender splash shields, axle bump stops and the k frame bolts. I got my tie rod sleeves into the evaporust which revealed some yellow paint on one end of each assy. I also cleaned some of the buffing compound off of a few areas, It felt good to take parts out of the "ready to be installed" totes and throw away some empty bags.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055733
04/14/12 11:28 AM
04/14/12 11:28 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Before shot of the grille? Maybe detail the original paint and how well the fatory detailed them
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055734
04/15/12 10:16 AM
04/15/12 10:16 AM
Virginia's Eastern Shore
dmoore Offline
dmoore  Offline
You mean like this?
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: dmoore] #1055735
04/15/12 10:40 AM
04/15/12 10:40 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Yep! It looked like one on the outter pass, and one on the drivers inner?? Final adjustment maybe? Off to the garage...
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055736
04/16/12 09:50 PM
04/16/12 09:50 PM
dmoore Offline
dmoore  Offline
Maybe,My sleeves & clamps are original, the outer & inner's were replaced a few years ago.....So......are we having fun yet??
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: dmoore] #1055737
04/18/12 08:38 PM
04/18/12 08:38 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Honeydo's got in the way of more progress, but I was able to get some things done. First thing was to bring down the pile of parts from the attic in the garage.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055738
04/18/12 08:41 PM
04/18/12 08:41 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Then I concentrated on getting the tail end done along with putting the rest of the misc brackets on the underside. I'm happy with the results.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055739
04/18/12 11:10 PM
04/18/12 11:10 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
I was hoping to have gotten the front suspension together by now. Unfortunatley I got the wrong part in the right box (the spindle mounting bolt holes were too small) on one of my lower balljoints. I have to wait for Rockauto to refund my $. The good news is that Amazon sells them (Moog) for the same price so I won't have to pay for shipping.
Tomorrow list of things to do includes:
1) Fuel and brake lines
2) Gas tank & straps
3) Refinish tie rod assy's and mount them to the centerlink.
4) Start on the headliner installation.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055740
04/19/12 09:52 AM
04/19/12 09:52 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Sounds like you got a drum brake ball joint. The ball joints are the same just not drilled to the bigger size.
https://board.moparts.org/ubbthreads/show...amp;Search=true
