Page 9 of 30 1 2 7 8 9 10 11 29 30
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055621
12/18/11 10:39 PM
12/18/11 10:39 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
After 2 days in Evaporust I pulled the snubber out. Polished it with steel wool and coated with RPM. I also replated the bolts.
Does anybody know if evaporust works slower when cold? Up next are the lower spring plates.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055622
12/19/11 12:23 AM
12/19/11 12:23 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, Evaporust works slower when it's cold, it also has a useful lifespan, basically derusting "X" #lbs of rusty metal parts before it starts getting week, eventually it stops working and becomes basically neutral.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: ScottSmith_Harms] #1055623
12/19/11 12:56 AM
12/19/11 12:56 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thanks Scott. I figured it may work slower in the cold (my garage is about 35 degrees), but I knew about its lifespan. Pretty neat stuff! Nothing like set it and forget it! I already figured out how to dip my leafsprings in it without needing 20 gallons.. That project is next on the list.
My plan is to get the rearend assy under the car as soon its ready to come off the rotisserie, along with casters in the front. Thanks go to RestoRick and his assembly sequence chart to make things go together quickly.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055624
12/19/11 01:49 AM
12/19/11 01:49 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
various sizes of PVC pipe is your friend when it comes to long parts
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: ScottSmith_Harms] #1055625
12/19/11 02:10 AM
12/19/11 02:10 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
4" leech line PVC tubing is $5 for 10' at Lowes. I plan to start with the longest leaves first then shorten the tube as I go.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055626
12/19/11 02:58 AM
12/19/11 02:58 AM
LC Valley - Idaho
GB5andGY8 Offline
GB5andGY8  Offline
LC Valley - Idaho
Brent, I just discovered this posting and hadn't realized you'd made this much progress since when I first saw this car. You do some excellent work!
Do you need a hand with any go-fer kind of stuff? I have been off this past month since I retired from the Navy and I have pretty much exhausted the honey-do list... it'd be nice to work on a Mopar and it might inspire me to work on the Charger.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: GB5andGY8] #1055627
12/20/11 01:03 AM
12/20/11 01:03 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Congrats on the retirement Paul, and thank you for your service! I definately could use some help on the big projects. My plan is to have everything done by the time the body gets back from painting. PM me your #
I think you should pick some small projects on the Charger to help get motivation rolling...
Wanna buy a 512 for it...
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055628
12/30/11 01:23 AM
12/30/11 01:23 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Been busy but haven't posted much. My router crapped out so my free wi fi disappeared, hence no pics for now. I've gotten the spindles, wiper transmission linkage, lower shock plates, tank straps, and some other parts all refinished and ready to go back on the car. Yesterday I picked up all my powdercoated parts! My chrome parts should be done next week.Today I sold a 72 Duster project and a 75 Dart parts car to help out with the $ part of the Dusters resto.
The Duster is in primer and is getting a little farther along each day....
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055629
12/30/11 06:59 PM
12/30/11 06:59 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Heres a great example of how well products like Evaporust work. A few days soaking and this is what comes out. I cleaned it off with some hot water and fine steel wool. Next up will be some RPM and Krylon battery protectant for that cosmoline dipped look.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055630
12/30/11 11:15 PM
12/30/11 11:15 PM
Canada
MUSLCA Offline
MUSLCA  Offline
Canada
Looking good.....
Wilson
Ontario
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: MUSLCA] #1055631
01/01/12 03:26 AM
01/01/12 03:26 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thanks MUSCLA!
HAPPY NEW YEAR TO ALL!!
Air cleaner is done!
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055632
01/01/12 12:00 PM
01/01/12 12:00 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Was the wife's oven involved at all?
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: moparpollack] #1055633
01/01/12 04:26 PM
01/01/12 04:26 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
I don't know what you're talking about....
Actually no spousal appliances were harmed in the beautifying of THIS air cleaner
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055634
01/01/12 08:59 PM
01/01/12 08:59 PM
Virginia's Eastern Shore
dmoore Offline
dmoore  Offline
Nice work Brent!
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: dmoore] #1055635
01/05/12 08:34 PM
01/05/12 08:34 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Thanks Dave!
I've been busy just haven't posted much. Today I got one of the leaf springs done. I had them sandblasted to save myself some time and picked them up yesterday. I took a rough scotchbrite pad to the exposed areas of the spring to smooth it out, along with a rubbing of heavy steel wool. I then stained them with gun bluing and then RPM. It took all day to one, so I'm done for today. Since it was 65 today it was a perfect outdoor project. Heres a before pic of the spring..
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055636
01/05/12 08:39 PM
01/05/12 08:39 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Heres the finished pic of the spring. All the hangers and the hardware have been redone, along with all new bushings front and back. I reproduced the orange paint mark I found on the front of the spring too. You can see how the springs looked when I picked them up yesterday. Only one more spring stack to go..
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055637
01/05/12 08:54 PM
01/05/12 08:54 PM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
In case anyones curious this is what the gun bluing looks like that I use. I bought it al Wal Mart in the gun cleaning section, its $3.43 and goes a long way. Works good to mimic the phospate look on bolts too.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055638
01/06/12 01:30 AM
01/06/12 01:30 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
Well today took it its toll. My harbor Freight heat gun quit working...time for another.
I also realized that Krylon battery protectant can't be applied on top of RPM.. so I'm stuck with my beautiful natural finish lower control arms without the cosmoline look unless I can figure out how to remove the RPM.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: NV69B7RR] #1055639
01/06/12 01:34 AM
01/06/12 01:34 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Well actual Cosmoline might work, there are also some other dips out there that will likely work.
Re: 71 Duster 340 4spd resto, from ruster to duster! [Re: ScottSmith_Harms] #1055640
01/08/12 11:04 PM
01/08/12 11:04 PM
MO
cdp Offline
cdp  Offline
MO
here's a link to what I had experimented with for the A12.....that still needs finished.
Anyways, Shafco makes some spray on cosmoline that is like original. I had to spray it about 15 times over the course of a week to get the look I wanted.
Only issue, its tacky and will attract dust.
https://board.moparts.org/ubbthreads/show...rue#Post5111652
Wish RPM was out at the time I did these a few years ago.
