Anyone have the Mallory or MP degree keys?
#1055393
08/18/11 09:47 AM
08/18/11 09:47 AM
Posts: 393 Sweden
Snoddas
Sweden
Hi, Mallory and MP have kits for degree the mechanical advance in the distributor. Its red keys for diffrent degrees. I want to know the thickness on the 18 and the 20 degrees red keys. Anyone have this kit? The mallory kit have part # 29014
1964 Dodge 330 Max Wedge clone 1965 Dodge Hemi A990 clone
Re: Anyone have the Mallory or MP degree keys?
[Re: Snoddas]
#1055394
08/18/11 09:56 AM
08/18/11 09:56 AM
Posts: 2,826 NY usa
540challenger
NY usa
I have it at the house, I could measure them when i get out at work later tonight if no one post. Also when using the keys I ran into a little problem with them. I used the 16* keys and only had 14* of mech advance when i install the dist. and tested it with my timing light. I then used the 18* keys and had 16* of mech advance
[Re: 540challenger]
#1055395
08/18/11 10:03 AM
08/18/11 10:03 AM
Posts: 393 Sweden
Snoddas
Sweden
Great keys...Not. Okay, then I may need the 22* key also. I should then see the measure diffrens between them also. I could easy set other degrees if needed. Would be super nice if you could measure the 18, 20, 22 then. Thanks for the trouble shooting also.
[Re: 360904]
#1055399
08/18/11 01:50 PM
08/18/11 01:50 PM
Posts: 2,415 Connecticut
Ron_M
Connecticut
FWIW, Here's the instructions P5153446
(1)
Common sense is a flower that does not grow in everybody's garden
[Re: 360904]
#1055404
08/18/11 02:33 PM
08/18/11 02:33 PM
Posts: 2,826 NY usa
540challenger
NY usa
I want 24* of initial and 36* total, so would I need 12* key??? or 24
You would need a 12* key. wow that is alot of initial timing may i ask why so much?????
[Re: 540challenger]
#1055405
08/18/11 02:41 PM
08/18/11 02:41 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
You would be looking for the 12* key (you want to key in the difference between your initial and the total). I too have seen that the keys are a little undersized, in that I had to use the 18* key plus a little slop to achieve 16 degrees of advance. My set starts at 14*. Here's what my caliper says on the 14, 16, & 18 degree keys: 14*: .140" 16*: .155" 18*: .170"
[Re: StealthWedge67]
#1055409
08/18/11 04:24 PM
08/18/11 04:24 PM
Posts: 393 Sweden
Snoddas
Sweden
Thanks, jepp I know but It save you some time if you are right first time I probably go for the 22* end up with 20* because it wasent any super duper accuracy. Hope to end up with 13-14* initial and total 33-34*
[Re: Snoddas]
#1055410
01/30/12 06:36 PM
01/30/12 06:36 PM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
Reviving the dead here a little. I just bought a small block dist and it didn't come with the advance keys (I assume that is a seperate kit). With the adjustments maxed out as it comes from the box, this should be 24* mechanical correct? The dist number is 3690426, and it has a thin brown spring and a thick silver spring on the advance just as an FYI. If I'm reading the graph above correctly, it should be all in by about 2800 rpm, yes? Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
[Re: phantomx]
#1055411
01/30/12 10:49 PM
01/30/12 10:49 PM
Challenger 1
Cincinnati, Ohio
