inexperienced at TnT #1052989
08/14/11 07:18 PM
08/14/11 07:18 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
I don't go to the track often enough to get good. In fact, I just do TnT occassionally because I'd get eaten alive in competition.
On street radials, is there any sense in doing even a dry burnout at the line?
Second, I had a surge midway through the 1/4, that I supposed was lean. But I then removed the air cleaner, and the car ran better, with no surge. Does this mean I was actually too rich with the air cleaner?
The good news, I did squeeze off a 13.59 at 98.72mph (about 500' above sea level IIRC) in my low budget 9:1 compression 360 A body. But I think it has more left.
I'm running an old 440 HP version of the AVS. Do I need fatter metering rods to lean it out some?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: inexperienced at TnT [Re: GO_Fish] #1052990
08/14/11 08:53 PM
08/14/11 08:53 PM
Yes, be careful though and do not get greedy, try .003 to no more than .005 at a time on all three steps The other way is to change both the primary and secondary jets down one size, AVS usually had high step jets in the front for the three step metering rods, some C body AFB had them also You can change the three steps to the standard two step rods and jets if you need to. You loose a tine bit of tuneability for economy on street driving at part throttle The choice is yours, BTW, are you running a AVS or AFB intake or a Thermoquad intake with a adapter? If with a adapter make sure your not impeding the flow from the carb. into the intake manifold on the primary side Ain't drag racing fun Most of the time
Re: inexperienced at TnT [Re: Cab_Burge] #1052991
08/14/11 09:05 PM
08/14/11 09:05 PM
Maryland
GO_Fish Offline OP
GO_Fish  Offline OP
Maryland
The AVS has been converted to 2 step AFB rods and jets. It is on top a 1/2" 4 hole spacer on a LD340 with the center divider mostly milled away per the old DC spec. The 360 is running full exhaust with early 340 manifolds.
Thanks for the help, I usually hang out on the Q&A or general forums side because I have so little to add on Unlawful's.
