Substitute for the metal fan shroud 62-65 b-body #1051502
08/12/11 01:10 PM
08/12/11 01:10 PM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Hi,
Anyone know of any stock looking substitute for the metal fan shroud (62-65 b-body 22" radiator).
Do any other mopar 22" fan shroud fit okay?
1964 Dodge 330 Max Wedge clone
1965 Dodge Hemi A990 clone
Re: Substitute for the metal fan shroud 62-65 b-body [Re: Snoddas] #1051503
08/12/11 04:23 PM
08/12/11 04:23 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Supposedly the Aspen slant-6 plastic shroud installed upside down is a good fit. As for a metal shroud, there was one for the late-'60s 22" radiator but it's apparently as rare as the early one.
Re: Substitute for the metal fan shroud 62-65 b-body [Re: topside] #1051504
08/12/11 05:35 PM
08/12/11 05:35 PM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Cool, it that one easy to find, sells it new? Will search for it.
Thanks!
Re: Substitute for the metal fan shroud 62-65 b-body [Re: Snoddas] #1051505
08/13/11 12:29 AM
08/13/11 12:29 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I found this one at a junk yard laying next to a Dakota so I think it was fron that Dakota. But my rad is not the stock one either. I cut a trimmed this one to make it work the best I could with this aluminum rad in my 63 Plymouth. Ron
Re: Substitute for the metal fan shroud 62-65 b-body [Re: 383man] #1051506
08/13/11 01:01 AM
08/13/11 01:01 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
That look great to boot! Good job!
I am in a world of crap when it comes to finding a shroud.
I have a corvette radiator that is like 16 inch high with a 23 inch wide core for my dakota. I can't find anything. I must be missing something.
Re: Substitute for the metal fan shroud 62-65 b-body [Re: 383man] #1051507
08/13/11 03:34 AM
08/13/11 03:34 AM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Looks great Ron.
Re: Substitute for the metal fan shroud 62-65 b-body [Re: Snoddas] #1051508
08/13/11 07:56 AM
08/13/11 07:56 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run a 65 C body 22 inch rad in my 65 B.Rad and shroud fit almost perfect.Junk yard price 14 years ago 40 bucks and still keeps it cool at 180 all day.Rocky
Chrysler Firepower
Re: Substitute for the metal fan shroud 62-65 b-body [Re: therocks] #1051509
08/15/11 09:07 AM
08/15/11 09:07 AM
E Central IN
N
nd65 Offline
nd65  Offline
N
E Central IN
I have the Aspen slant 6 shroud upside down on mine. The caution tab is now on the bottom. I cut it off.
You will need to fab the mounts a bit.
Re: Substitute for the metal fan shroud 62-65 b-body [Re: nd65] #1051510
09/08/11 11:37 AM
09/08/11 11:37 AM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Hi again,
I have found a volare slant 6 fan shroud, I'm not so good at thoose cars but shouldnt that be the same, aspen and volare 1980.
The Mopar part # is 4140318
Re: Substitute for the metal fan shroud 62-65 b-body [Re: Snoddas] #1051511
09/08/11 09:51 PM
09/08/11 09:51 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
You don't want the original shroud?
Re: Substitute for the metal fan shroud 62-65 b-body [Re: 52savoy] #1051512
09/09/11 10:32 AM
09/09/11 10:32 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The determining factor is usually cost,everyone list them for more money as Max Wedge fan shrouds which they are not,the two piece metal shroud was used on A/C equipped cars 62/65 and later maximum cooling packages until the change to the molded one piece shroud.
Re: Substitute for the metal fan shroud 62-65 b-body [Re: Snoddas] #1051513
09/09/11 12:31 PM
09/09/11 12:31 PM
E Central IN
N
nd65 Offline
nd65  Offline
N
E Central IN
Aspen/Volare should be the same.
I run mine upside down so it is offset to match the car.
You will need to fab the mounting. Not a big deal.
It is not factory correct but is cheap and effective. I don't really care about being "correct" on every aspect of my car.
Good luck.
Re: Substitute for the metal fan shroud 62-65 b-body [Re: nd65] #1051514
09/11/11 06:07 PM
09/11/11 06:07 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
did small blocks&big blocks both use a metal two piece shroud in those years?
Re: Substitute for the metal fan shroud 62-65 b-body [Re: Joesixpack] #1051515
09/11/11 06:34 PM
09/11/11 06:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
All were 22" radiator,used the same shroud.
Re: Substitute for the metal fan shroud 62-65 b-body [Re: 62maxwgn] #1051516
09/11/11 08:56 PM
09/11/11 08:56 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
C-body different?
Re: Substitute for the metal fan shroud 62-65 b-body [Re: Joesixpack] #1051517
09/11/11 08:57 PM
09/11/11 08:57 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
ok whats this 1
Re: Substitute for the metal fan shroud 62-65 b-body [Re: nd65] #1051518
09/12/11 03:17 AM
09/12/11 03:17 AM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Good luck.
I won it - 99 cent and brand new.
Its not correct but its lightweight and cheap!
