Page 1 of 3 1 2 3
604 Predator dyno session complete #1051237
08/11/11 06:20 PM
08/11/11 06:20 PM
Salt Lake City
camastomcat Offline OP
Salt Lake City
So I'm going to start this thread saying that these guys did a great job on a motor I spec'd out. My specific instructions were a fast bracket motor that might have some light NOS(150-200)and would go 200+ passes without rebuilding or changing valve springs often and would run Sonoco Maximal fuel, all day long. I was told going into the project that the dyno we were using was somewhat conservative, and I know we don't race dynos...well some of us do. The sheets I will post will show the best pull with 2 carbs, and the only pull with one carb. It was also not my intention to wear the thing out on the dyno. So although I was hoping for more, I will get it in the car by MATS and we'll see what it yields on the track. That's what counts in my world.
Re: 604 Predator dyno session complete [Re: camastomcat] #1051238
08/11/11 06:21 PM
08/11/11 06:21 PM
Salt Lake City
Salt Lake City
The other sheet.
Re: 604 Predator dyno session complete [Re: camastomcat] #1051239
08/11/11 06:27 PM
08/11/11 06:27 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
That's good hp. With a single carb. Conrats.
Re: 604 Predator dyno session complete [Re: camastomcat] #1051240
08/11/11 06:30 PM
08/11/11 06:30 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Able to do 200 passes and minimal spring changes pulling down 1150hp sound awesome to me. Helluva fun ride! Sounds like you got a exactly what you wanted. Great balls of fire!
Let us know how the track treats you.
Damon
Re: 604 Predator dyno session complete [Re: camastomcat] #1051241
08/11/11 06:31 PM
08/11/11 06:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its not far off what you were looking for... I'd say
you did pretty darn good
Re: 604 Predator dyno session complete [Re: camastomcat] #1051242
08/11/11 06:35 PM
08/11/11 06:35 PM
Salt Lake City
Salt Lake City
Here's one pull. Follow the link.
http://www.youtube.com/watch?v=yzx6lFeX6fU
Re: 604 Predator dyno session complete [Re: camastomcat] #1051243
08/11/11 07:09 PM
08/11/11 07:09 PM
Salt Lake City
Salt Lake City
Here's the last one. Just 1 carb and the last dyno sheet.
http://www.youtube.com/watch?v=O1nghpMhTmI
Re: 604 Predator dyno session complete [Re: camastomcat] #1051244
08/11/11 11:11 PM
08/11/11 11:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I like it!
Re: 604 Predator dyno session complete [Re: camastomcat] #1051245
08/11/11 11:19 PM
08/11/11 11:19 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I think it blew the exhaust off at the end of the pull! I like it
Re: 604 Predator dyno session complete [Re: Dodgem] #1051246
08/11/11 11:21 PM
08/11/11 11:21 PM
Did you do any pulls above 7500 RPM? It looks like it was still gaining power at the cut off RPM on the tunnel ram sheet
Re: 604 Predator dyno session complete [Re: Cab_Burge] #1051247
08/11/11 11:37 PM
08/11/11 11:37 PM
Salt Lake City
Salt Lake City
Really, I didn't want them to beat the heck out of it and it won't see anything over 7800-8000 in the traps. So, since I wasn't there, I can't answer that for sure, but I doubt it. When I get it in the car, I'll play with the shift points, but I'm glad it lost less than 40HP with one carb. Marcella did a great job on the intake. Maybe I'll come out to the Mopar deal at Woodburn again next year and you can come over and say hi Cab.
Re: 604 Predator dyno session complete [Re: camastomcat] #1051248
08/12/11 12:37 AM
08/12/11 12:37 AM
new jersey
gillman34 Offline
gillman34  Offline
new jersey
We could have pulled it higher but the plan was not to beat it up on the dyno. It is built with all the best parts and can surely handle the higher rpm. The time slip will tell the true tale!
The puff of white smoke at the end of the pulls is steam from the water brake on the dyno,yes the water gets that hot!
Overall we are very happy with the results.The engine sealed up well(always a battle with an aluminum block),has great vacuum,and has a flat torque curve.
I,for one,can't wait to hear how it performs in the car!!!
Re: 604 Predator dyno session complete [Re: gillman34] #1051249
08/12/11 12:43 AM
08/12/11 12:43 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Nice! Hey Steve, give me a call next time you plan on running one of those. I'd be interested to come out there and check it out...
MB
Re: 604 Predator dyno session complete [Re: gillman34] #1051250
08/12/11 12:46 AM
08/12/11 12:46 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Nice job Steve
How ya been?
RIP Monte Smith
Re: 604 Predator dyno session complete [Re: gillman34] #1051251
08/12/11 12:47 AM
08/12/11 12:47 AM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
Motor sounds great and torque curve is nice and flat, will be very interesting to hear how your car performs by comparision to the B1 engine your were running before IIRC.
Best of luck to you the predator is a very nice top end.
Are you changing convertors or is the torque similar enough I am wondering if you will need a tighter converter ?
76 Duster work in progress
Re: 604 Predator dyno session complete [Re: camastomcat] #1051252
08/12/11 12:55 AM
08/12/11 12:55 AM
Are you ging to at Boise for the division 6 bracket finals? If so maybe I'll try to look you up, if I can remember to
Re: 604 Predator dyno session complete [Re: camastomcat] #1051253
08/12/11 09:08 AM
08/12/11 09:08 AM
Get-X Offline
Get-X  Offline
Very nice!! Congratulations on building an awesome engine. As others mentioned, anything that can make 200 maintenance free laps and make 1150 hp doing is no disappointment. Please keep us updated on how it all works out in the car.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: 604 Predator dyno session complete [Re: Get-X] #1051254
08/12/11 11:15 AM
08/12/11 11:15 AM
detroit area
moderncylinder Offline
detroit area
actually made 1044,, corrected to 1152 108 in the correction
Re: 604 Predator dyno session complete [Re: moderncylinder] #1051255
08/12/11 11:33 AM
08/12/11 11:33 AM
tboomer Online work
tboomer  Online Work
Looks pretty good,Tom!!
Re: 604 Predator dyno session complete [Re: camastomcat] #1051256
08/12/11 12:30 PM
08/12/11 12:30 PM
NC
440Jim Offline
440Jim  Offline
NC
The 604 CID did like the additional air flow. Was that the same tunnel ram with a single carb top? What size are the carbs?
Looks good.
Page 1 of 3 1 2 3
