Re: 604 Predator dyno session complete
[Re: moderncylinder]
#1051259
08/12/11 03:13 PM
08/12/11 03:13 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
actually made 1044,, corrected to 1152 108 in the correction
Well I don't put much creedance in dyno numbers, but in track ET numbers. I'll know when I get it all tuned up and the right converter in the car and make some clean passes. Plus it's the win light that motivates me to do this stuff, not some thoeretical number from a dyno. Also, I've never seen a dyno sheet that didn't have corrected numbers.
[Re: camastomcat]
#1051260
08/12/11 03:45 PM
08/12/11 03:45 PM
camastomcat
Salt Lake City
Congrats! You made nearly identical power to my 604ci BBC HH motor, but I'm guessing you paid a little more!!lol
You might be suprised from what I've seen. I looked at going with the GM stuff and though there are alot more options, they didn't look to be cheaper at this level with all of the upgrades I picked.
The 604 CID did like the additional air flow. Was that the same tunnel ram with a single carb top? What size are the carbs?
It was the same intake. I had it made with 2 tops from Marcella.
Are you ging to at Boise for the division 6 bracket finals? If so maybe I'll try to look you up, if I can remember to
I live in Salt Lake and we are IHRA here so unless Woodburn needs somebody to fill in, I can't get in.
Are you changing convertors or is the torque similar enough I am wondering if you will need a tighter converter ?
I'm going to try the one I am using and see what the results are, but I can have another one built, if I need to. Jim at Torque Converter Works is a freind of mine and has built lots of high end converters so if I need one looser or tighter, he just a call away.
Thanks for the support guys and I'll post when I get it in the car and have some real results. That's what I don't see enough of here, real results. I wish more people dyno numbers vs ET and MPH numbers. And if they could let us know the type of car, weight with driver, and altitude, we would know what some of these numbers mean and if corrected numbers lie. That's the real comparison IMO and the only reason I post like this is to help the poor fool like me that is considering any type of build.
[Re: camastomcat]
#1051261
08/12/11 06:10 PM
08/12/11 06:10 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
You dont see a lot of "results" numbers because everyone here wants to race dynos. Its funny how many combos never get reported on again ...and never do we see any of the big track numbers their dyno numbers should support. There is way more to a combo than a good dyno number, but Hot Rod magazine doesnt sell good without the big numbers. You did fine, and who cares what you paid for it. YOU got what you wanted, had a good guy build it, and its YOUR money. I'm glad you did it your way and sounds like you had a great plan. A lot of guys just want to get caught up into the " my Johnson is bigger" race, but on track results are what counts.You had a plan, stuck with it, and actually put thought into what you wanted, and had YOUR specific goals set. That is wonderful in my book. Good luck to you.
RIP Monte Smith
[Re: Al_Alguire]
#1051265
08/13/11 10:31 PM
08/13/11 10:31 PM
camastomcat
Salt Lake City
Sounds like it made some good steam for sure Tom. Are you going to make it to the Turkey race with the new bulet? Look forward to seeing it in action.
That race scares me Al. If you go, be real careful several people crashed last year and many were dragsters. Good luck though if you decide to go. I'm going to try to make the div. after the national. And with this motor, traction will be more challenging, even with a "street motor". Now that's funny right there.
[Re: Al_Alguire]
#1051266
08/13/11 10:39 PM
08/13/11 10:39 PM
camastomcat
Salt Lake City
The turkey race is somewhat dangerous Al, even with a "street motor" now that's funny stuff. I will try to make the show at the divisional in T/D with the predator, if I can get it done.
[Re: fishy340]
#1051271
08/14/11 12:56 PM
08/14/11 12:56 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
I can guarantee the poke on the PSO deal was at me. As I was the one that stated lets see what it runs. I am sure the PSO deal of B1johnny will run very well. You have to know the context even on that comment to uderstand why it was made When it is all said and done I hope we here the numbers from both combos in thier respective cars, I am sure they will both work well. Trying to run in T/S or T/D is not easy at all. As the years go on it is going to get harder and harder to make those fields. Tom no worries on the Turkey day race. My junk dont make enough power to have a problem. We will of course be at the Divisional running S/ST.
[Re: Al_Alguire]
#1051272
08/14/11 01:29 PM
08/14/11 01:29 PM
Posts: 127 Long Island, NY
B1Johnny
Long Island, NY
Don't worry Al I'll post my runs/timeslips as well as on board videos with cameras from Cudafied (Part Of The Action). Probably not untill the begining of next season unless someone wants to sponsor me to get the car done
[Re: B1Johnny]
#1051273
08/14/11 01:43 PM
08/14/11 01:43 PM
Al_Alguire
Las Vegas
I think we couls all use a sponsor Best of luck with the car. Trying to run T/S is no easy task for sure. I will be waiting to see the results. As someone pointed out earlier we often see some dy no numbers but never hear how they ran in the car. Always nice to see track results. I know my junk is an underachiever but being a S/ST racer I have never been to concerned with the ultimate ET from the car. Be watching both combos to see the results. Always tough to compare a suspended digger to a door car. I am sure I will see Tom's in person. We have been thinking of building a real engine for my heap for next year. So interested in seing the results. Have been leaning toward the Predator stuff but I have a good pair of B1 heads and may just go much bigger than my current set up. But might just have a whole new car all together. One last tidbit some here dont include is the DA the car runs in. Tom spends most all his time running at tracks with bad air. I would best most of the time he is in in 4000'+ DA's. The MATS is probably the best air he sees other than going to Oregon or Boise a year. I know last time we went out the DA was between 5500-6000'. Feels like I am towing a boat behind me
[Re: Al_Alguire]
#1051274
08/16/11 03:30 PM
08/16/11 03:30 PM
camastomcat
Salt Lake City
Hey Al, 5500-6000 is good air here. I've seen it at 8500 before. Talk about knocking the wind out of your combo. I hope you are doing well down there, and yes your car makes killer power for being a dwarf in a giant world. I remember seeing you go in the 8.40's at Vegas a while back, right? Anyways, stay in touch. I'm going to try to get all my stuff put together to install the Predator sometime in September, if possible. I'll let you know the results as our last race is the end of September here .
