Pushrod oiling for BB?
#1050267
08/10/11 09:02 AM
08/10/11 09:02 AM
Posts: 6,148 Melbourne , Australia
LA360
How is it best set up? I am sourcing parts for a friends B1 build and wondering if we are going to be able, or if we should even bother with setting up his engine to pushrod oil. I haven't organised roller lifters as yet, he has the T&D early common shaft rocker system and a World Block. We are both small block guys and first timers with this Big Block stuff.
Thanks in Advance!
Alan Jones
Re: Pushrod oiling for BB?
[Re: LA360]
#1050268
08/10/11 09:21 AM
08/10/11 09:21 AM
Posts: 10,012 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I bought the Comp lifters from Brian at Indio motor machine. They have the oil feed hole 90 degrees to the oil passage, which restricts flow the right amount. Pushrod oiling is the best way to go. Positive flow to the most vital parts. You may need to leave the shaft oiling in place, possibly restricted. Call T&D to see what to do there.
[Re: LA360]
#1050269
08/10/11 09:52 AM
08/10/11 09:52 AM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
Thanks in Advance!
I used the common shaft B1 stuff for several builds, and it works fine. The pushrod oiling is better, but if you have the common shaft system, I would use that unless you have the dough to buy a whole new system, but the World block is set up for either. PS Pushrod length is of paramount importance.
[Re: camastomcat]
#1050271
08/10/11 12:09 PM
08/10/11 12:09 PM
Posts: 1,288 Oregon
sg66mopar
Comp Cams lifter # 892C-1 and link bar # 829-L. You have to buy each piece individually. Comp doesn't offer these as a kit. You can also go with offsets if you want but I stuck with the centered lifters. My engine builder believes there's too much side loading on the lifter bore with the offset lifters. If he has the aluminum race block with oil holes in the lifter bores that's more than half the battle. It's easy to plug the shaft oiling holes in the World block. I did lose a few PSI oil pressure when I switched to the T&D individual shaft - pushrod oil setup.
[Re: astjp2]
#1050273
08/10/11 07:41 PM
08/10/11 07:41 PM
LA360
Thanks for the replies. I have contacted T&D via email and will wait on their reply before doing anything else. We were looking at Isky, Bullet or CamFX roller lifters. My friend just wants it to be reliable and will spend a little extra on certain parts if need be.
Alan Jones
[Re: gregsdart]
#1050275
08/11/11 12:09 AM
08/11/11 12:09 AM
Posts: 469 Tennessee
steeldust
Tennessee
I agree with you GREGSDART on that . I have a 572 world block and INDY 440-1 heads with T&D rockers & comp lifters and push rod oiling with smaller oil lines to the heads BRAD & me built the motor and it oils perfect and BRAD knows motors.
