Plugs for boosted SB? #1049176
08/08/11 02:58 PM
08/08/11 02:58 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Getting very close to first fire of my turbo setup and I'm down to the little things..plugs carb etc. I was wondering what plugs I should get for this. Motor is as follows:
Bone stock 76 318(kerosene burning compression)
Old torker 340 intake
stock cam(for now)
650 holley
GT45 turbo, shooting for 10lbs out of the gate and intercooled
3.5in open downpipe
cheapo 2800 converter
3.55 gears with 26" tire (going to 28"s for the look)
This car will be primarily street driven but will see some passes at TNT and a few grudge runs...
Re: Plugs for boosted SB? [Re: SLOW67] #1049177
08/09/11 03:06 PM
08/09/11 03:06 PM
NC
SLOW67 Offline OP
SLOW67  Offline OP
NC
Guess I'll just run good ole autolite 66's
Re: Plugs for boosted SB? [Re: SLOW67] #1049178
08/10/11 05:41 PM
08/10/11 05:41 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
with 10 lbs of boost you should be fine with a projected tip plug, anymore and you should run a non-projected tip, if you call ngk plugs, they have a guy in the tech department that is real savy with blown and turbo stuff, he can point you in the right direction for the best plug, i don't have their number handy but if you do a google search you can find it.
Re: Plugs for boosted SB? [Re: SLOW67] #1049179
08/12/11 02:47 AM
08/12/11 02:47 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Autolite 3923's would be a good start.
