What is good converter slippage? #1048683
08/07/11 04:52 PM
08/07/11 04:52 PM
Canada/USA
ragingram Offline OP
Canada/USA
My friend uses a Bruno and he says he has his locking up at 98%
I've checked how well my 727 is locking up and its is always between 96-98% Usualy 97%
Is that good or bad? Never really checked it out before.
Re: What is good converter slippage? [Re: ragingram] #1048684
08/07/11 05:04 PM
08/07/11 05:04 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
96-98 % is pretty good ....is this WOT up on the big end? ... ATF temp?
Re: What is good converter slippage? [Re: ragingram] #1048685
08/07/11 05:22 PM
08/07/11 05:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you talking a "lock up converter" if so thats
not great.... if your talking a normal "NON lock up"
then I would say go back and check your numbers ...
that is almost too good to believe... if you get
5% slippage you should be real happy... if you get
3%... jump for joy because thats SUPER GOOD
Re: What is good converter slippage? [Re: MR_P_BODY] #1048686
08/07/11 05:50 PM
08/07/11 05:50 PM
Canada/USA
Canada/USA
I should had mentioned this is for super stock truck pulling.
So its not a lock up converter.
I have a sensor that tells me the tire speed and then i calculate how fast they should have been turning by my gear ratio and just figure out the percentage that way.
Coverter starts to bite at 2000 and is suppose to be a 3500 stall
Every time i do the calculations its between 96 and a few at 98 but it happens. When it is running close to 8000rpm is when i see it closer to 98. At low 7000 it usualy around 96%
Re: What is good converter slippage? [Re: MR_P_BODY] #1048687
08/07/11 05:57 PM
08/07/11 05:57 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I would only trust a good data recorder where you can read the graph precisely nothing else.
home of the
Sox and Martin Hemi Duster
Re: What is good converter slippage? [Re: ragingram] #1048688
08/07/11 05:58 PM
08/07/11 05:58 PM
Florida STAYcation
Florida STAYcation
That heavy of a load ? ...... I would say that the piece is not high-stall at all.
Re: What is good converter slippage? [Re: BeEtLeJuIcE !] #1048689
08/07/11 06:30 PM
08/07/11 06:30 PM
Canada/USA
Canada/USA
It is a Dataquest by altronics.
There is no shifting. pulling off the line in 3rd (dirrect). The differentials are REALLY low gearing. Usually have a final gear ratio of 21-1 to around 23-1
Re: What is good converter slippage? [Re: ragingram] #1048690
08/07/11 06:41 PM
08/07/11 06:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Since your reading a data logger what does it say it
is at about 5000 rpm... if its a 2800 stall or so
it should show about the same.... to be honest I've
never seen (or heard of) 2% slippage... unless some
numbers are wrong..... I have a driveshaft sensor
so it is a direct relation to the engine rpm... the
engine rpm is X and the driveshaft is X = the conv
slippage
Re: What is good converter slippage? [Re: MR_P_BODY] #1048691
08/07/11 07:01 PM
08/07/11 07:01 PM
Canada/USA
Canada/USA
slippage
I understand what you mean. The data logger won't tell me the right slippage because my driveshaft sensor is on my lower driveshaft. Not the one coming right out of the engine. I need a full shield around my top driveshaft (trans to transfer case) so i couldn't put the sensor there. So all my data logger is properly telling me is the MPH of the tire speed. When it tries to calculate the slip on its own its calculating it from just the 6:80 gears in the differentials and not the reduction in the transfer case also.
If i tell it the final ratio it will get the slippage right maybe but then the mph wrong. I've called altronics and they were working on an idea how to fix my problem so it would read both properly without being on the top driveshaft.
So when i calculate the slippage I take the MPH of the tire that the Data logger is telling me. Then im dividing by the speed they should be turning if there was 0 slip.
Isn't it true though that a lower stall converter will have less slip at higher RPM's then if it was a 5000 stall? i just remember hearing that somewhere.
Re: What is good converter slippage? [Re: ragingram] #1048692
08/07/11 07:29 PM
08/07/11 07:29 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yes thats true! IMO it shouldnt matter if your sensor is on the second driveshaft off the transfer case. As long as you use the correct mechanical gear ratio.
Re: What is good converter slippage? [Re: Sport440] #1048693
08/07/11 07:50 PM
08/07/11 07:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
... the sensor should be reading the same
as on the front shaft .... and yes low stall will
have less slippage so maybe you are in the right range
Re: What is good converter slippage? [Re: MR_P_BODY] #1048694
08/07/11 08:16 PM
08/07/11 08:16 PM
Canada/USA
Canada/USA
More i think about it more i think your right. I keep confusing myself. The sensor is on the lower driveshaft. So it is spinning slower then the top one cause its going through the transfercase. In my datalogger is asks for differential ratio.. So i put in 21 whish is my final ratio but when i made a run it said i was spinning either 100mph or 10 mph i forget but it was way off.... So next time i just wrote in 6:80 (my differential ratio) and it would give me numbers like 30mph whitch is about right.
Maybe i'll just call Altronics again and let them walk me through it again.
thanks for the help guys!!
Re: What is good converter slippage? [Re: ragingram] #1048695
08/07/11 08:25 PM
08/07/11 08:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I forgot that you are running through a tranfer case
so the ratio would change
Re: What is good converter slippage? [Re: MR_P_BODY] #1048696
08/07/11 09:11 PM
08/07/11 09:11 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I've never seen pulling truck pull that wasn't throwing clay for 50 ft.
It's hard to nail down converter efficiency when the tires are spinning.
Big RPM and that much gear reduction is going to show it's fairly
efficient. Then add in the tires aren't "hooked".
Re: What is good converter slippage? [Re: S/ST 3040] #1048697
08/07/11 09:45 PM
08/07/11 09:45 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Thats a good point!
In that case you wont really know the vert efficiency to the track.
But you would still know the vert efficiency as measured with sensors between the crank/vert/ final drive output of any gear reduction. Requardless of any measured ET or tire slippage.
Re: What is good converter slippage? [Re: Sport440] #1048698
08/07/11 11:28 PM
08/07/11 11:28 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Converter slippage numbers can be missleading under certain circumstances. For example, if you at the top of the gear and the car is out of breath, the efficiency numbers will be unuasully high. I would bet your not accelerating near the trap, or way out of gear.
Edit: I am running a PTC converter in a turbo application and hope to get around %4 slippage. This is bassed on similar combinations running the same converter and considered to be extreamly good.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: What is good converter slippage? [Re: turbobitt] #1048699
08/08/11 09:04 AM
08/08/11 09:04 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
What club do you pull with?
