E-body carpet...how far up the firewall should it go #1047913
08/06/11 12:27 AM
08/06/11 12:27 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
I'd like to see some pictures of survivor cars if possible to see where the factory cut the carpet. I just started to loosley install the carpet in the Challenger and I have lots of excess material. I've got enough extra material to completely cover the steering column hole. I think I can trim some of it off outside the car to make things easier. Right now there is so much extra that I'm going to be scratching up my E-brake and brake pedals.
Also, it looks like there is a crease in the heel pad. Is that crease supposed to go where the floorpan starts to angle up...just below the gas pedal? Thanks
Re: E-body carpet...how far up the firewall should it go [Re: burdar] #1047914
08/06/11 06:48 AM
08/06/11 06:48 AM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
You should not see and part of the fire wall when walking up to the car or sitting in the seat.
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: E-body carpet...how far up the firewall should it go [Re: MMC Detroit] #1047915
08/06/11 06:49 AM
08/06/11 06:49 AM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Re: E-body carpet...how far up the firewall should it go [Re: MMC Detroit] #1047916
08/06/11 06:50 AM
08/06/11 06:50 AM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Re: E-body carpet...how far up the firewall should it go [Re: MMC Detroit] #1047917
08/06/11 06:58 AM
08/06/11 06:58 AM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
Final ref
Re: E-body carpet...how far up the firewall should it go [Re: MMC Detroit] #1047918
08/06/11 09:31 AM
08/06/11 09:31 AM
Iowa
burdar Offline OP
Owen's Dad
burdar  Offline OP
Owen's Dad
Iowa
Those were perfect...thanks!
That "crease" or "seam" that is in the heel pad is about 3" back from the front face of the pad. If I possition that seam right where the floorpan starts to angle up, that leaves the front section of carpet overlapping the rear section by about 3/4". Unless I hear different, that's where I'm going to put it.
