.5 ohm dual circuit ballast resistor #1047215
08/04/11 04:35 PM
08/04/11 04:35 PM
Hangtowner Offline OP
My 1975 Chrysler repair manual says the dual circuit ballast resistor should be .5 ohms on one side. I measure 1.5 ohms on my samples and the replacements that I find are also advertised as 1.5. I see that Accel advertises a .5 ohm dual circuit resistor. Should I use that one with a stock coil and ignition box? My car seems a bit livelier when I hot wire the coil.
Re: .5 ohm dual circuit ballast resistor [Re: Hangtowner] #1047216
08/04/11 11:35 PM
08/04/11 11:35 PM
I ohmed a dual one (high miles) & got 1.6/6 & I wired them parallel & got 1.1 ohms. I wouldn't b araid to use the Accell one & dont think you'd have a prob w .5 ohms. What's the value on the other half of it? info from a prior thread: ign coils are either .5 or 1.5 ohms (pri). Most aftermarket performance coils and early chrysler coils are .5 ohms. the ballast turns .5 ohms into 1.5 ohms because .5 ohms will overheat the coil. E coils are .5 ohms but will not overheat. Chry ECU type coils or aftermarket coils you must retain the ballast. Late coils like on lean burn are 1.5 ohms & can use WO ballast.
