Re: Bump Steer
[Re: MR_P_BODY]
#1046232
08/03/11 01:36 AM
08/03/11 01:36 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
If you get the Mopar Chassis book it will tell you all about it and how to correct it
Yep, torch and a pipe wrench, oh, you'll need a tape measure also
Re: Bump Steer
[Re: MR_P_BODY]
#1046233
08/03/11 10:29 AM
08/03/11 10:29 AM
Posts: 2,177 ill
dennismopar73
ill
mr p,, how about tell us what the root cause is of bump steer, how could it accours in a stocked steered car,? and some ways , to fix
Re: Bump Steer
[Re: dennismopar73]
#1046234
08/03/11 10:39 AM
08/03/11 10:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Its just the height differences of the inner and outer tie rods and lengths... they have you change the heights.... once you do a toe curve you can determine whats needed
Re: Bump Steer
[Re: dennismopar73]
#1046235
08/03/11 10:59 AM
08/03/11 10:59 AM
MR_P_BODY
Also being that the upper and lower control arms are different in length and the different mounting points(for cornering) the arc's are different so it pulls inwards through the travel... thats why I like a stutt suspension so much better
Re: Bump Steer
[Re: 10.90 Racer]
#1046237
08/03/11 11:14 AM
08/03/11 11:14 AM
MR_P_BODY
Aside from heating and bending.... are there other alternatives?? I know there are bumpsteer kits. Not many for Mopars... There is the Hotchkis kit. It is VERY NICE but also expensive.......
Not that I'm aware of
Re: Bump Steer
[Re: MR_P_BODY]
#1046238
08/03/11 12:06 PM
08/03/11 12:06 PM
Posts: 1,409 Ont. Canada
10.90 Racer
super street
super street
Ont. Canada
That's not that answer I was looking for........... LOL
Re: Bump Steer
[Re: rowin4]
#1046240
08/03/11 12:23 PM
08/03/11 12:23 PM
10.90 Racer
super street
super street
Ont. Canada
Do you have or can you get the mopar chassis book? maybe something on line about bump steer from the book. It's been years since I did mine , lost the book in Katrina.
I'm going to look at the book. I'm sure I have a couple around.....
Re: Bump Steer
[Re: rowin4]
#1046241
08/03/11 12:23 PM
08/03/11 12:23 PM
Posts: 2,177 ill
dennismopar73
ill
i have looked form it my self, friend of mine ad one so he took a couple pages and photo copied some pages but not all of it said go to the library get it my self found out some time ago getting info from fellow racers is very hard, they want to die with their secrets'of sucess hahahlol
Re: Bump Steer
[Re: dennismopar73]
#1046243
08/03/11 12:38 PM
08/03/11 12:38 PM
10.90 Racer
super street
super street
Ont. Canada
The book tells you to bend the arms on the lower ball joint..... you can use Rod ends in place of Tie rod ends now. I would like to find a way to make up this set up myself. The threads on the Mopars are 9/16 (Odd ball) so they do not lend themselves to any easy 5/8 Rod end conversion. There are no 5/8 to 9/16 sleeves availible.....
Re: Bump Steer
[Re: MRMOPAR]
#1046246
08/04/11 01:11 AM
08/04/11 01:11 AM
MR_P_BODY
Good info there...
Thats right out of the Mopar Chassis book..... looking at that F, M, J front end brings back memories... I was part of the design team on that front end... been a long time since then
Re: Bump Steer
[Re: MR_P_BODY]
#1046247
08/04/11 02:50 AM
08/04/11 02:50 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I have the manual, I have a torch with a rosebud.. I have a car I want to correct but I've never gotten comfortable with heating & bending suspension parts..... Should the parts be allowed to cool naturally or quenched? Dull red glow or bright red before bending?
Re: Bump Steer
[Re: 1_WILD_RT]
#1046248
08/04/11 09:25 AM
08/04/11 09:25 AM
MR_P_BODY
Naturally
