Re: anyone put a 318 poly in a 41 frame?
[Re: dart_451]
#1045942
08/02/11 06:19 PM
08/02/11 06:19 PM
moparpollack
Lil Herman
Lil Herman
85086
No but it would look cool. I was looking at putting a push button tranny behind a newer 360.
[Re: RodStRace]
#1045945
08/02/11 09:57 PM
08/02/11 09:57 PM
Posts: 34 topeka,ks
dart_451
topeka,ks
yea the steering is messed up.i have the motor just sitting on the frame and the steering rod looks like it would go through the valve cover when set in right. im looking at the 3 joint shaft and u-joints by borgeson that fat man fabs make. maybe that will do it.that poly is soo much wider at the heads than a normal small block.
[Re: Marty cRUIZer]
#1045949
08/03/11 09:37 PM
08/03/11 09:37 PM
Posts: 34 topeka,ks
dart_451
topeka,ks
wow,never thought of the manifold switch.and what kind of motor mount set up did you use? did you weld boxes on the k-member where needed? and i will never put brand-x in any of my mopars!
[Re: dart_451]
#1045951
08/09/11 11:31 PM
08/09/11 11:31 PM
Posts: 141 Marysville, OH
Marty cRUIZer
Marysville, OH
I had square tubing welded to the frame with biscut mounts. I got the engine side brackets from Chassis Engineering. Are they still in business?
Marty Marysville, OH
