Special tool #104589
08/13/08 11:23 PM
08/13/08 11:23 PM
Loma Linda, MO
7812845 Offline OP
7812845  Offline OP
Loma Linda, MO
Any one know of a special tool to remove female connectors on firewall wiring harness. I just removed the dash wiring harness and the main bulkhead and noticed a lot of corrision. I know they'll come out, but my scratch awl is just a little to big and kinda distorts the plastic. What do you all use???
2020 RAM Longhorn 4x4
2022 Jeep Grand Cherokee Overland
Re: Special tool [Re: 7812845] #104590
08/14/08 12:13 AM
08/14/08 12:13 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I use a very small flat blade screwdriver. Looking at the open end of the terminal, you'll see a tang on the outside edge of every terminal. This tang keeps the terminal from backing out of the plastic bulkhead. Push the terminal all the way in, insert small screwdriver to bend tag flat (toward terminal), then pull terminal out.
Upon installation, simply bend that tang upward agan and insert into the proper cavity. The tang will have some spring to it, so it will keep the terminal in postion when fully seated in the bulkhead.
I bet Lisle makes a tool specifically for this, though. Check on eBay, as they do have a tool for the round terminals.
