would you race w/ this tire? #1044764
08/01/11 01:13 PM
08/01/11 01:13 PM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
ok, i got a new set of bfg drag radials 275 60 15 this year and put maybe 20 miles on them and 2 short burnouts, no runs at the track yet. last weekend i took my brother for a short drive and after we got back the passenger side went flat. i just put some air and found a bad leak like i ran over a nail or something. my question is would you feel confident having the tire patched or repaired by a tire shop and running at the track? doing burnouts and airing down the tires? i'm hoping for low 12's or high 11's so maybe 115 mph. maybe faster as it feels a lot stronger with the new motor. i don't know much about tires so i don't know how reliable a patched tire is. they are almost brand new and expensive. do i need to buy a new tire and patch this one as a spare or will it be ok????? thanks for any input, dave
Re: would you race w/ this tire? [Re: dirtybee] #1044765
08/01/11 01:39 PM
08/01/11 01:39 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
If it's just a small hole I'd pull it off break it down put a patch inside and run it till it's worn out!
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: would you race w/ this tire? [Re: DragDart360] #1044766
08/01/11 02:11 PM
08/01/11 02:11 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
Hello! If you have it done correctly, it will be as good as new. Yes, some manufacturers say the warranty is "void" if patched (on performance tires that is), but at my shop we have done many race tires, drag tubes, etc..I wouldn't worry about it. Jeff
Re: would you race w/ this tire? [Re: dirtybee] #1044767
08/01/11 02:22 PM
08/01/11 02:22 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes, and you don't air down radials they work better with 17psi and better.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: would you race w/ this tire? [Re: 1967dartgt] #1044768
08/01/11 04:12 PM
08/01/11 04:12 PM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
Hey thanks everyone, that puts my mind at ease I'm glad to hear that. I
When I say air down, I meant down to 18 psi from 33-35 psi on the street, I would think running at 17-18 psi all the time would wear the tires out faster
Re: would you race w/ this tire? [Re: dirtybee] #1044769
08/01/11 10:45 PM
08/01/11 10:45 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My drag radials have 2 plugs in the sidewall. Has never been an issue. Car runs 11.0@124
Doug
Re: would you race w/ this tire? [Re: dvw] #1044770
08/01/11 10:55 PM
08/01/11 10:55 PM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
My drag radials have 2 plugs in the sidewall. Has never been an issue. Car runs [Email]11.0@124[/Email]
Doug
SWEEEET!!! sounds like a fun ride
Re: would you race w/ this tire? [Re: dvw] #1044771
08/01/11 11:30 PM
08/01/11 11:30 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Doug
Doug your scaring me!!!!!!!!!!!!!!!Jake PS Doug give me a call
JAKES AUTOMOTIVE
Re: would you race w/ this tire? [Re: JAKE68] #1044772
08/02/11 02:02 AM
08/02/11 02:02 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
Doug
Me too!! Chief
Re: would you race w/ this tire? [Re: JAKE68] #1044773
08/02/11 05:15 AM
08/02/11 05:15 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Doug
Between the shoulders, within the tread pattern, OK. Plugs in the sidewall? That had to have been a joke. No Way, too much flexing going on there.
Re: would you race w/ this tire? [Re: Dean_Kuzluzski] #1044774
08/02/11 05:53 AM
08/02/11 05:53 AM
sweden
sshemi Offline
sshemi  Offline
sweden
do you think the thread doesnt flex?
those plugs, if installed correct, will hold up fine.
Re: would you race w/ this tire? [Re: sshemi] #1044775
08/02/11 06:04 AM
08/02/11 06:04 AM
Holly/MI
Holly/MI
Sure, the tread flexs too. But there's LESS belts in the sidewall and more stress when cornering.
Just giving an opinion. I worked for a tire store as a young man for over 2 years and we NEVER messed with a sidewall repair. EVER. Did LOTS of flat repairs back then. It wouldn't happen on my ride for sure.
Good day.
Re: would you race w/ this tire? [Re: Dean_Kuzluzski] #1044776
08/02/11 09:08 AM
08/02/11 09:08 AM
tboomer Offline
tboomer  Offline
Little over a week ago,I ran over something at the track and put a hole in one of my slicks. It was pretty close to the sidewall and I don't think I would trust a patch or a plug going thru the traps at 127.00 mph..Ended up putting tubes in for my own peace of mind...
Re: would you race w/ this tire? [Re: tboomer] #1044777
08/02/11 11:55 AM
08/02/11 11:55 AM
sweden
sshemi Offline
sshemi  Offline
sweden
if you can go with a tube thats the best way
