Page 2 of 12 1 2 3 4 11 12
Re: Jeep Build - For Off Roading and MPG [Re: Defbob] #1044545
08/09/11 09:44 PM
08/09/11 09:44 PM
Chicagoland
Cooter Offline
Cooter  Offline
Chicagoland
Another nice rig. Makes me miss my M170, in a weird way.
Re: Jeep Build - For Off Roading and MPG [Re: Cooter] #1044546
09/03/11 01:34 PM
09/03/11 01:34 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Now that the budget has increased for the Willys (Due to Tom owning it now....), I will be building it specifically for Peterson's 4Wheel & Offroad Ultimate Adventure 2013
Re: Jeep Build - For Off Roading and MPG [Re: Defbob] #1044547
09/03/11 01:57 PM
09/03/11 01:57 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Tom ended up buying the PRICEY 4BT last night
He bought an entire Frito Lay truck
Does the frito lay truck have 19.5 Single rims? If so Id be interested
I like these old willys
Re: Jeep Build - For Off Roading and MPG [Re: Defbob] #1044548
09/04/11 10:07 PM
09/04/11 10:07 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Since Tom hasn't posted a pic of the Willys he bought off of me here you go....
Also, I decided to put a diesel in my Dodge M37 and suddenly he has to have one as well
Gotta love those old Willys!
I saw an orange one about 10 years ago at Carlysle (sp), had a 350 bowtie and a lift kit. VERY Sweet truck, but i couldn't get past the Chevy power.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Jeep Build - For Off Roading and MPG [Re: 76dodgeboy] #1044549
09/05/11 08:42 AM
09/05/11 08:42 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
16", its on a 1977 P30 chassis
Re: Jeep Build - For Off Roading and MPG [Re: Defbob] #1044550
09/24/11 06:30 PM
09/24/11 06:30 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I finished removing the 4BT from the Frito Lay truck while Tom removed the rest of the body. The motor is tiny once it is sitting all by itself. About the length of a 2.2L but taller. I will be swapping the drive assembly from one of my 6BT to give Tom a Chrysler alternator and an AC compressor. I will also be installing my vacuum pump onto his motor. (My deuce won't be needing a vacuum pump )
The 4BT is getting repainted the Cummins Beige that it already is. I will paint Tom's A518 trans and NP205 the same color as well.
Re: Willys Wagon Build - For Off Roading and MPG [Re: moparts] #1044551
06/30/13 03:59 PM
06/30/13 03:59 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I started on the frame for Tom's Wagon since my Dart is off at the bodyshop. It is made from 3x4" 3/16 wall tubing. I am stretching the wheelbase to 112". I have a set of Rubicon Express 1.5" SOA springs and leaf spring hardware from Ruff Stuff. The front D-ring shackles are from Ballistic Fabrication and were the only one long enough to fit through the 3" thick crossmember. The crossmember is the front bumper, that way nothing will be directly in front of the front tires.
Re: Willys Wagon Build - For Off Roading and MPG [Re: Defbob] #1044552
06/30/13 04:00 PM
06/30/13 04:00 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
All tacked together.
Re: Willys Wagon Build - For Off Roading and MPG [Re: Defbob] #1044553
06/30/13 04:00 PM
06/30/13 04:00 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
and square... I hope
Re: Willys Wagon Build - For Off Roading and MPG [Re: Defbob] #1044554
06/30/13 04:02 PM
06/30/13 04:02 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I will finish weld the connections next weekend and add some gussets to certain areas. Gonna be Ultimate Adventure strong
Re: Jeep Build - For Off Roading and MPG [Re: Defbob] #1044555
06/30/13 08:55 PM
06/30/13 08:55 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
What size Rims does it have and are the Super singles aka Non-dually
Re: Jeep Build - For Off Roading and MPG [Re: 76dodgeboy] #1044556
06/30/13 08:57 PM
06/30/13 08:57 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I didnt see how old the post was
Re: Jeep Build - For Off Roading and MPG [Re: 76dodgeboy] #1044557
06/30/13 11:19 PM
06/30/13 11:19 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
It had dually wheels
Re: Jeep Build - For Off Roading and MPG [Re: Defbob] #1044558
07/21/13 08:29 PM
07/21/13 08:29 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
4BT is waiting for me to make the new water inlet/alternator/A/C bracket
Re: Jeep Build - For Off Roading and MPG [Re: Defbob] #1044559
07/21/13 08:30 PM
07/21/13 08:30 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
New TJ Wrangler Hellwig 1-1/4" swaybar
Re: Jeep Build - For Off Roading and MPG [Re: Defbob] #1044560
07/21/13 08:31 PM
07/21/13 08:31 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Dodge Dana 60 front axle that I narrowed to 63.8" wide and fully rebuilt with locker waiting to go in.
Re: Jeep Build - For Off Roading and MPG [Re: Defbob] #1044561
07/21/13 08:32 PM
07/21/13 08:32 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Houston, we have pintle
Re: Jeep Build - For Off Roading and MPG [Re: Defbob] #1044562
07/21/13 08:33 PM
07/21/13 08:33 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Crosby shackles came in the other day
Re: Jeep Build - For Off Roading and MPG [Re: Defbob] #1044563
07/21/13 08:34 PM
07/21/13 08:34 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
attached to the Ballistic Fab weld-through d-ring mounts
Re: Jeep Build - For Off Roading and MPG [Re: Defbob] #1044564
07/21/13 08:35 PM
07/21/13 08:35 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
front frame step reinforcement
