66 convertable rear panel screws??? #1043691
07/31/11 09:00 AM
07/31/11 09:00 AM
crlush Offline OP
crlush  Offline OP
Hello on my 66 coronet convert. does anyone know the correct screws that attach the rear convertable armrest panel on the top (you can see them along the bottom of the rear quarter window) there is 3 per side. my car came with a different screw in each hole and im not shure any of them are the right one. if anyone has any pics it would help, im shure most 66-70 b-bodys would use the same screws. thanks in advance
Re: 66 convertable rear panel screws??? [Re: crlush] #1043692
08/01/11 06:42 AM
08/01/11 06:42 AM
crlush Offline OP
crlush  Offline OP
Re: 66 convertable rear panel screws??? [Re: crlush] #1043693
08/01/11 11:14 AM
08/01/11 11:14 AM
Arizona
az426john Offline
az426john  Offline
Arizona
I have takes some photo's for you from my 1967 Belvedere convertible.
I am realatively sure these are the original screws and should also be correct for your car.
They are too large to post so PM me and I will send them to you via email.
