Hemi air cleaner with edelbrock carbs. modifications? #1042753
07/29/11 08:10 PM
07/29/11 08:10 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I heard that the only way to get the oval hemi air cleaner to work with the edelbrock carbs is to cut the baseplate larger. Is this true? If so has anyone done this?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Hemi air cleaner with edelbrock carbs. modifications? [Re: 73cuda340] #1042754
07/29/11 11:21 PM
07/29/11 11:21 PM
ontario canada
426lloyd Offline
426lloyd  Offline
ontario canada
call Art at Mancini's , I got one from him to fit the larger throat for the edelbrocks
Re: Hemi air cleaner with edelbrock carbs. modifications? [Re: 73cuda340] #1042755
07/30/11 12:01 PM
07/30/11 12:01 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
I make a fiberglass part for precisely what you want to do. $150. Looks like this only the holes are slightly closer together and the "necks" are a cut to fit design. The one pictured is for a Stage V setup and doesn't have a cut to fit setup.
