Re: block off exhaust crossover on B manifold?
[Re: ademon]
#104254
08/13/08 03:12 PM
08/13/08 03:12 PM
Posts: 2,507 Royersford, PA
bschargerse
Royersford, PA
The car will be parked in the winter months, if the weather is mild I might take it out. The carb will have an electric choke. Unless I go with the AVS, in which case I'll have to leave the passage open for the choke coil.
Brian - 1971 Dodge Challenger "The Dodge, which was practically stock, just left the Mustang like you wouldn't believe."
[Re: StealthWedge67]
#104258
08/14/08 03:09 PM
08/14/08 03:09 PM
bschargerse
Royersford, PA
I was thinking the same thing, isn't cooler air more dense, allowing for better atomization?
[Re: bschargerse]
#104262
08/14/08 06:58 PM
08/14/08 06:58 PM
Posts: 21,503 It's a dry heat
gtx6970
It's a dry heat
Is there a valley pan available with a blocked crossover
Yes.
[Re: bschargerse]
#104264
08/14/08 09:49 PM
08/14/08 09:49 PM
Posts: 30,490 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
A warm/hot intake makes for better atomization.
Why do you think Ma Mopar puts heat in the intake ? ... and with a blocked crossover ... the mixture has to be fatter to make it more "driveable". That is the purpose of the choke ...correct?
[Re: 63stabamatic]
#104268
08/15/08 07:22 AM
08/15/08 07:22 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
If you don't need the heat to operate the automatic choke then block it. I couldn't get my stock AVS choke to open all the way with the crossover blocked, even with a new choke control. I took the block out, now I wish I would have just changed carbs, as it's much hotter!
or just installed the electric choke off an ebrock on the AVS ....
[Re: dOc …]
#104269
08/15/08 07:25 AM
08/15/08 07:25 AM
JohnRR
You don't think that the A/F ratio goes rich on a cold-start ..... even when it is 70 degrees outside ?
it does to a degree by function of the choke flap being closed .
keep reaching
![](/ubbthreads/images/graemlins/popcrn.gif)
