Re: where and which 509 cam to buy?
[Re: shoebox]
#1042361
07/31/11 02:09 AM
07/31/11 02:09 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
hughes engines will not get a penny of my money
i have had 100% good luck and customer service with Hughes. I have their shelf solid in mine.
What happened?
[Re: 493_DART]
#1042362
07/31/11 09:29 AM
07/31/11 09:29 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
My 408 has their solid, my pump gas 340 with one of their hydraulics ran 7.24 in the 1/8 at 3300#.
[Re: shoebox]
#1042365
07/31/11 07:08 PM
07/31/11 07:08 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
If you go with the 509 get the 108 LS cam and not the 112. If it were me I would use the solid you have now With Either cam, I would still want the adjustable rockers. So thats a given IMO. Ive tossed pushrods with the stock rockers with the smaller MP 484 cam. 10.8,s are easily doable in a A body with your current cam, 10.5 comp, 4000+ stall, 3.91 or 4.10 gear.
[Re: shoebox]
#1042368
07/31/11 10:08 PM
07/31/11 10:08 PM
Sport440
Canton, Ohio
108 is the only choice. It's the adjustable rockers I would want To get away from. That's the point of this whole idea!
I hear you, . But I would still recommend them.
[Re: Sport440]
#1042369
08/03/11 11:19 PM
08/03/11 11:19 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
just shove the 509 in and give it a go - you know you want to they make the power when packeged right my Satellite just dropped into the teens last night at a street meet 11.189@119.00 and 11.187@118.95 Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1042370
08/04/11 07:55 AM
08/04/11 07:55 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I think you should use the solid cam, i use iron rockers and have only adjusted them once this year. What rockers do you intend to run and what is the rest of your combo. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1042371
08/04/11 01:43 PM
08/04/11 01:43 PM
Posts: 808 mckinney texas
shoebox
mckinney texas
3500lbs w me dart sport 440 11.0cr Cast crank ly rod shortblock 2295s stealth heads ported to 300+ My comp solid 250/255 530/540 108 OR 509 type hyd 6-6200 rpm limit with ethier Torker2 800 Holley Pro parts 2 in TA 3800++ stall (is going in for upgrades can be 4xxx stall) 370 gear 26 in tires for now Probably go 410 28 Adjustable rockers- I'd like some affordable 1.6s. 200-650 bucks VS 100 dollar Mopar HD stamped rockers. I know the solid would be Better.... There is no question. But I just can't help but think The lil ol 509 will get the10.90 goal met !
[Re: mike54]
#1042373
08/04/11 06:30 PM
08/04/11 06:30 PM
deaks
robin hood country
I dont think your car will go 10's with the .509, carb is too small, converter needs more stall and it's too heavy. I reckon 11.20-30 JMHO Mick
[Re: shoebox]
#1042374
08/04/11 08:27 PM
08/04/11 08:27 PM
Sport440
Canton, Ohio
Yes, it will be tough! I didnt know the combo was that heavy. If I added 550# to my 2950# combo, it would slow it down from a 10.47 to 11.10 or so.
My verts not the best, 4200, but with a new 5000 stall, it might hit a 10.98 with that added weight.
73 Sport 440, 509 cam w/Eddys 3.91 and 28.1"/27.3 tire. Et. 60 ft. 1.435, 1/8th. 6.61 @ 101.80 mph. 1/4. 10.472 / 127.78 mph. 2950# race/with me,and pump gas.
