Convertimg rear wheel HP to Fly Wheel HP? #1042254
07/28/11 05:42 PM
07/28/11 05:42 PM
MA
ragtop Offline OP
ragtop  Offline OP
MA
If I get 250 rear wheel HP with manual trans
(340, 4spd. power steeing connected, G60 x 15 polyglass, stock exhaust). What is my old fashion fly wheel HP? Thanks.
Re: Convertimg rear wheel HP to Fly Wheel HP? [Re: ragtop] #1042255
07/28/11 06:05 PM
07/28/11 06:05 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Probably about 325. But that's a guess. Not as much drivetrain loss with a 4 speed.
Re: Convertimg rear wheel HP to Fly Wheel HP? [Re: viperblue72] #1042256
07/28/11 06:55 PM
07/28/11 06:55 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Roughly 18-20% loss so about 300-312 at crank
JAKES AUTOMOTIVE
Re: Convertimg rear wheel HP to Fly Wheel HP? [Re: ragtop] #1042257
07/28/11 07:09 PM
07/28/11 07:09 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I am not a believer in trying to get a "good" flywheel hp number from a car that was on a chassis dyno. At best,it is a guess.
Chassis dynos can be a great tuning tool if used as such,but to get a flywheel number you need an engine dyno.
I don't intend to make this an argument about which is better/worse,each has it's place. I wish I owned one of each but I had to stick with one.
Keith
Re: Convertimg rear wheel HP to Fly Wheel HP? [Re: Dunnuck Racing] #1042258
07/28/11 09:54 PM
07/28/11 09:54 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Keith you are right. I have seen that when I compared the two known numbers sometimes it did not come close with the normal formula that i follow. I only use it because most of the guys want a number. I use my dyno for mostly a tuning tool and really don't care what the numbers are the car will tell the real story. I wish i could afford both also. Jake
JAKES AUTOMOTIVE
Re: Convertimg rear wheel HP to Fly Wheel HP? [Re: JAKE68] #1042259
07/28/11 09:58 PM
07/28/11 09:58 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Before I bought my engine dyno I thought about a chassis dyno.....for about 3 seconds. Dave
