Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: Todd] #1041285
07/27/11 04:37 PM
07/27/11 04:37 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I forgot about adding the ladder bars into the equation
I'd assume when just using leafs you'd want some more forward movement, correct?
Sorry to hijack Randy
I'll buy you a when I see you @ Norwalk
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: roadhazard] #1041286
07/27/11 04:53 PM
07/27/11 04:53 PM
Ohio
Todd Offline
Todd  Offline
Ohio
When the shocks are on, there is no way for the slider to bottom out in any direction. Works very smooth. Way better than the shackle mess.
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: Todd] #1041287
07/27/11 06:21 PM
07/27/11 06:21 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Geez...by now you could've had the Caltracs installed and been out doing this... LOL
Just saying
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: actionange] #1041288
07/27/11 10:52 PM
07/27/11 10:52 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Stopped by Jake's Automotive today,and talked to Gary. He's going to re-mount my rear shackles..and check my pinion angle. Can't believe how crazy-busy they are over there! His parking lot was filled to capacity!...that's a GOOD thing! If this does knock off .1...I'll be VERRRY happy! Thanks for ALL your help..and pictures,guys! That's what makes Moparts members the BEST!!!
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: Labratt] #1041289
07/28/11 10:37 AM
07/28/11 10:37 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
This in mine! I thought they were suppose to be straight up. I also have a hole in front of the one I am using. Would I be better off in the front hole?
Uploaded with ImageShack.us
67' charger 499 RB 10.57 at 127
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: dragram440] #1041290
07/28/11 10:43 AM
07/28/11 10:43 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Matt..from what the "experts"(Jake & Mr. P-Body)are telling me...the shackle should be at least 30* angle for the spring to work correctly! Not sure if more angle is better or not? Might want to use that existing hole! I would!
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: dragram440] #1041291
07/28/11 10:50 AM
07/28/11 10:50 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
IMO......YES, YES, YES
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: dragram440] #1041292
07/28/11 11:13 AM
07/28/11 11:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes it should have the top leaning forward... if you
were to lift the body you shackle will run out of
travel vs if the top was forward... also if its too
far forward it will bottom out on the rear when the
spring goes into compression/jounce... so more isnt
necessarily better
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: Labratt] #1041293
07/28/11 12:24 PM
07/28/11 12:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Can I get some "Real World" opinions...from the actual experience of correcting a "neautral" angle(straight up and down)to a "corrected" angle of 30 degrees forward(top of shackle)? I'm VERY curious as to the difference it made in the 60' times! I am talking about Super Stock springs. My angle is at this position because I'm using the 002/003 A-Body springs on my '69' GTX....and apparently the rear attaching point has to be moved forward 1-1/1/2" Thanks in advance for your information! Randy B.
If you look REAL close to my sig photo you`ll see AIR and a 1.36 60 ft. THAT`S the real benefit from proper leaf spring rotation/movement. Fix the little things and big things will come.
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: Thumperdart] #1041294
07/28/11 06:07 PM
07/28/11 06:07 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Dom..1.36 60's for a STREET CAR is Awesome! Like Steff,yourself,and a few others have suggested,if I correct the suspension..and tweak a few things...I just might be closer to that 10.999 time slip! We'll see when the weather cools off!
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: Labratt] #1041295
07/28/11 07:12 PM
07/28/11 07:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Exactamundo................. When I was teaching Cab about racing years ago , I kept preaching about finessing EVERY part of the car from bumper to bumper and look at him today! Your car`s bad a$$ to me and runs hard so keep at it.
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: Thumperdart] #1041296
07/28/11 10:07 PM
07/28/11 10:07 PM
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: Cab_Burge] #1041297
07/28/11 10:24 PM
07/28/11 10:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Come on Cab,(joke) just jerkin your chain and you`ve taught me loads of good stuff and are good friend.
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: Thumperdart] #1041298
07/29/11 12:37 AM
07/29/11 12:37 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Dom! That ole' Cab sure took what ya taught him and put it to good use! He's a "Smart Cookie" as well as yourself!
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: Labratt] #1041299
07/29/11 02:09 AM
07/29/11 02:09 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Funny stuff............. Good luck with your car and the cooler weather.
Re: BENEFITS OF A CORRECTED REAR SHACKLE HANGER??? [Re: Thumperdart] #1041300
07/29/11 10:26 AM
07/29/11 10:26 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
THANK YOU!....and good luck with that "big-tired" Nova!
