68 Dart GTS #1038920
07/24/11 01:02 PM
07/24/11 01:02 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Is there an easy way to tell if a gts dart is a real 4-speed gts big block car. Thanks
Re: 68 Dart GTS [Re: bobs69] #1038921
07/24/11 01:16 PM
07/24/11 01:16 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Fender tag, VIN (engine only), torque plates, welded pivot ball support on the frame side. Match the VON on the fender tag to the rad support and trunk lip numbers. Match them to the VIN with the broadcast sheet. Without all the support numbers and docs you can't be sure.
