Varnish in Gas Line #1038499
07/23/11 02:59 PM
07/23/11 02:59 PM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
My Cuda has sat for a lot of years , I can blow air through the gas line but it has gummie stuff in it, anything magic to clean it out with other than a new line, also how to hook up rods on a 68 4speed with an inland, can't find my service manual.
Re: Varnish in Gas Line [Re: 340mouse] #1038500
07/23/11 04:24 PM
07/23/11 04:24 PM
midwest
I
intragration Offline
I
midwest
If it were me, and as long as the line wasn't rusted out or completely blocked, I'd hook it up and start using it. New gasoline flowing through it should probably clean it up.
Re: Varnish in Gas Line [Re: 340mouse] #1038501
07/23/11 04:34 PM
07/23/11 04:34 PM
Arizona
az426john Offline
az426john  Offline
Arizona
If it were me, I would carefully run acetone through it until it came out clear or almost clear.
Re: Varnish in Gas Line [Re: 340mouse] #1038502
07/23/11 07:16 PM
07/23/11 07:16 PM
michigan
2
21966mopars Offline
21966mopars  Offline
michigan
I had the same issue with my 66 300 I bought the por gas tank renew kit. pulled the tank and re did the tank with the kit. after that blow out the lines.Run a clear filter and replace after a tank of gas.Mine has been trouble free since.
Re: Varnish in Gas Line [Re: intragration] #1038503
07/23/11 07:20 PM
07/23/11 07:20 PM
USA
ramairthree Offline
ramairthree  Offline
USA
true that.
you may need to give the carb a going though after a while, years of varnish and tiny dust specs of rust that get through the filter can surprise you.
but after that you should be good
Re: Varnish in Gas Line [Re: ramairthree] #1038504
07/23/11 08:23 PM
07/23/11 08:23 PM
NY NY
3
340duster340 Offline
NY NY
true that.
ditto, i have also on occasion spliced in a better mesh type filter at the car while running the crud out of the line.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: Varnish in Gas Line [Re: 340duster340] #1038505
07/24/11 02:04 AM
07/24/11 02:04 AM
Alaska
73rrak Offline
73rrak  Offline
Alaska
The car I'm building now sat in a field for 15 years with no gas cap. What what was once fuel in the tank came out of the tank like tar. The tank was trash and I couldn't blow air through the fuel line. I capped the fuel tank side of the fuel line and used a small funnel to fill the fuel line up with sea foam at the engine compartment end. after about a week I took the cap off and all of the crap came out. I flushed it with Acetone until it ran clear.
Re: Varnish in Gas Line [Re: 73rrak] #1038506
07/24/11 08:58 AM
07/24/11 08:58 AM
I'd for sure flush it thoroughly however way you choose 2 do that and or replace the lines/tank. I wouldn't want it going to my carb. Gas is problematic enough the way it is
Re: Varnish in Gas Line [Re: RapidRobert] #1038507
07/24/11 10:23 AM
07/24/11 10:23 AM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
sea foam? what is this.
Re: Varnish in Gas Line [Re: 340mouse] #1038508
07/24/11 10:43 AM
07/24/11 10:43 AM
Dirty South, MS
mopowered Offline
mopowered  Offline
Dirty South, MS
Seafoam is a top cleaner sold at the auto parts stores. In the gas tank it helps melt the varnish and buildup away from metering holes & injectors. Directly into hot idling carb or throttle body (whole can then shutoff & soak for 1hr) will remove carbon from tops of pistons & back of valves. I stock up at Advanced Auto when it goes on sale. Lot of people swear by it and call it a tune up in a can. All my vehicles are addicted to it - especially my 300C.
Re: Varnish in Gas Line [Re: mopowered] #1038509
07/24/11 10:52 AM
07/24/11 10:52 AM
Although I have an aversion to magic elixor snake oil products of any kind that you pour/add to an eng I have heard good about Seafoam but I'll stay w my earlier post
