Tire size #1035794
07/19/11 09:55 AM
07/19/11 09:55 AM
WV
JohnH Offline OP
JohnH  Offline OP
WV
Installing 15'X8 wide Cragar Mags on a 69 Charger, I'm going to put BF Goodrich TAs on the car. what size tire will be a good size to install? Just a cruzn tire.
Re: Tire size [Re: JohnH] #1035795
07/19/11 10:18 AM
07/19/11 10:18 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
If you want the ability to rotate your tires, then go with all four the same. I have found that 255/60R/15's look great on a '69 Charger. I have 15x8 magnums on my Daytona and they fill the wheel wells rather nicely and give a great stance. I've never had issues on tire rub. Now, if you want a slight rake look, then maybe 255's up front and 275's in the rear...
Troy
Houston Mopar Connection Club
Re: Tire size [Re: JohnH] #1035796
07/20/11 12:09 PM
07/20/11 12:09 PM
Detroit, Michigan, USA!
peelerboy Offline
peelerboy  Offline
You could easily go as wide as 275's on back (with a 60-series radial), but you'd then lose your rotate-ability if you didn't put the same beefy shoes up front. hemi68charger's recommendation is probably the best. 255's would look really good all the way around.
Dale
Re: Tire size [Re: JohnH] #1035797
07/20/11 12:11 PM
07/20/11 12:11 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
215/75/15 or 225/70/15 up front and 275/60/15 rear.
good website for sizing
http://www.1010tires.com/tiresizecalculator.asp
Coming soon!!!!
