Re: MP P4876337 intake
[Re: cudarex]
#103508
08/12/08 11:26 AM
08/12/08 11:26 AM
BradH
So, your saying it will fit over this Indy plate with EZ heads.
I don't think that's what he's saying at all... nor do I believe it will.
[Re: BradH]
#103509
08/12/08 11:34 AM
08/12/08 11:34 AM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
Looks to me from his picture that it's setting over a plate. Not sure about the screws. Might have to use a button head type.
[Re: cudarex]
#103510
08/12/08 11:37 AM
08/12/08 11:37 AM
BradH
Yeah, I took another look... it's shown setting over an AR Engineering plate, not an ICH plate. Not sure how they compare. I'd think you'd need to run the ICH spacers like they offer for EZ and SR heads to use the standard valley tray and rely on the built-in tray on that intake to seal off the valley. Maybe it's less of a hack than it sounds like, but it seems to me like more possible sources for oil leaks.
[Re: RemCharger]
#103514
08/12/08 01:03 PM
08/12/08 01:03 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
this intake is not for stage 6 heads or raised runner indy's right? this intake is for stock, max wedge or rpm heads ported to max wedge size, correct? i thinks its a great option if i have that straight
[Re: sixpackgut]
#103517
08/12/08 01:07 PM
08/12/08 01:07 PM
Posts: 31,029 Oregon
AndyF
Correct. This would be the way to mount a single 4bbl intake to either stock Max Wedge heads or RPM heads that were ported to MW size. It is the only way that I know of to do that trick with an OOTB intake manifold.
[Re: sixpackgut]
#103518
08/12/08 01:13 PM
08/12/08 01:13 PM
AndyF
fuel rail mounts for efi
Could be I guess. Not sure why they did that since MP has never shown any interest in providing a retrofit EFI kit for big blocks though. Maybe some engineer had an idea about EFI but it got shut down before any progress was made?
[Re: AndyF]
#103520
08/12/08 04:04 PM
08/12/08 04:04 PM
BradH
Here is a view from the front. I think this shows the double valley tray a little better. It would be hard to make some spacers that fit into the ends since they would have to have V shaped notches to mate with the Indy heads.
Hmmmm... if that's the intake I had to run w/ that combination, I'd start looking at the easiest way to off the built-in valley cover and just run the ICH / AR Engineering plate under what's left of the intake.
[Re: cudarex]
#103522
08/12/08 04:25 PM
08/12/08 04:25 PM
sixpackgut
Charleston
and smear some grease on the wall behind the engine!!!!
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: ZIPPY]
#103524
08/12/08 04:31 PM
08/12/08 04:31 PM
BradH
I wonder if there's enough meat in the casting (before the carb pad is cut) to make a 4500 version
I'd expect so, considering MP did the same "trick" (ummmm... hack?) to the Stage VI RB intake that's similar in design.
