Re: HOLLEY 950HP VS. RACE DEMON RS TEST RESULTS!!!
[Re: Labratt]
#1034703
07/18/11 07:02 PM
07/18/11 07:02 PM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
good to hear your results Randy,what was the bg sleeved to cfm wise ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Labratt]
#1034705
07/18/11 08:49 PM
07/18/11 08:49 PM
tex013
Sydney,Australia
Randy, so would you say the BG was bigger/flowed more than the Holley ? just trying to correlate it to my experiences re finding where the motor simply cannot use more air/bigger carb
Tex
[Re: Labratt]
#1034707
07/18/11 09:36 PM
07/18/11 09:36 PM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
So what about on the street Randy, I'm still looking to make a move from the MD-850 and it's wonderful idle qualities....
That's what you used to run right?
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: Labratt]
#1034709
07/18/11 11:52 PM
07/18/11 11:52 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Glad you got out and had some fun.
I think the carb is actually 870 cfm. It has the 1.375 venturi.
Hard to believe that it would want that much jet.
[Re: Labratt]
#1034715
07/19/11 02:41 AM
07/19/11 02:41 AM
tex013
Sydney,Australia
thanks Randy. just shows what your motor wants,similar to my experience my 440 needed more than a ultra hp950,loves my bg 825(bigger),didn't gain with a prosystems hp1000 based carb(biggest). my heads and cam are the restriction.cam will change - not the heads can't / won't step up to the 10.0's - too many extra regs and rules you have a great looking GTX
Tex
