2806301 intake date #1033710
07/16/11 05:12 PM
07/16/11 05:12 PM
Pennsylvania
craigerlitz Offline OP
Pennsylvania
Normally the date is located on the top of the intake, but on a couple of intakes there are other numbers as 9 X 1 or 9 X 3 where I would expect to see the date. Could any of you tell me what these numbers mean? Do these represent a day? If not, where can I find the build date?
Thanks,
Craig
Re: 2806301 intake date [Re: craigerlitz] #1033711
07/18/11 10:17 PM
07/18/11 10:17 PM
Pennsylvania
Pennsylvania
Here is a picture of the 9X3 date.
Thanks,
Craig
Re: 2806301 intake date [Re: craigerlitz] #1033712
07/18/11 10:22 PM
07/18/11 10:22 PM
Pennsylvania
Pennsylvania
I am use to a date as 9.27.67 on intakes. What is the date for 9X3?
Thanks,
Craig
Re: 2806301 intake date [Re: craigerlitz] #1033713
07/18/11 10:46 PM
07/18/11 10:46 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I'm not sure if it is as simple as 9 X 3 = September 3rd, but there are two 2806301 intakes on ebay with similar date codes (one being 11 X 7). Some water pump housings are coded in the same manner, but I've never seen somebody state the actual decode of the date. That intake was used for two model years (1968 & 1969), so that adds a little more to the mystery (is it 9/3/67 or 9/3/68?). What year & did the format change (for the 2806301 intake) or are they all "number X number".
Re: 2806301 intake date [Re: 6bblgt] #1033714
07/18/11 10:52 PM
07/18/11 10:52 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Is the first number always 1 thru 12 (or 01 thru 12)
& the second number 1 thru 31?
Re: 2806301 intake date [Re: craigerlitz] #1033715
07/18/11 11:07 PM
07/18/11 11:07 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
Another point of interest, this intake is bolted to a block with a casting date of 2-8-68. I'll try to get the vin off of the block tomorrow.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: 2806301 intake date [Re: RTDaddy] #1033716
07/22/11 12:22 AM
07/22/11 12:22 AM
Pennsylvania
Pennsylvania
So are these dated month X day? What do the 1 and the 2 stand for that are next to the pentastar logo? How do you determine which year they were cast?
Thanks,
Craig
Re: 2806301 intake date [Re: craigerlitz] #1033717
07/22/11 08:49 AM
07/22/11 08:49 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I have 3 or 4 301 intakes , I'll have to make note of the date and such.
