440 exhaust flange gasket #103255
08/11/08 04:39 PM
08/11/08 04:39 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
Just recently rebuilt my 69 440 HP motor. When I put it back in the car, I find that I have developed a persistant exhaust leak at the flange. I am running Stock HP exhaust manifolds with a stock (H-pipe)system. Who makes a thicker and more surable exhaust flange gasket to stop the ticking?
Re: 440 exhaust flange gasket [Re: TrueTripleX] #103256
08/11/08 04:51 PM
08/11/08 04:51 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Not sure on the "better" quality exhaust-doughnuts, but you might also consider more sturdy exhaust-hangers/supports.
Is your mounting-hardware (exhaust bolts/studs) in good condition? Sometimes new bolts/studs/nuts and even SS flat Washers provide better cinching-action.
Application of a little high-temp Ultra-Copper Silicone, applied to the exhaust-gasket helps too.
Finally, could there be a crack in the exhaust-pipe or manifold?
Re: 440 exhaust flange gasket [Re: D_C] #103257
08/11/08 04:55 PM
08/11/08 04:55 PM
Ball Ground GA
Ball Ground GA
Thanks D C. I will try the Ultra Copper. All of the studs looked good and there were no cracks in the manifold. I have tried to find a thicker flange gasket, but have not had any luck. Any ideas on where to get a thicker one since I have to take the system apart anyhow?
Re: 440 exhaust flange gasket [Re: TrueTripleX] #103258
08/11/08 05:33 PM
08/11/08 05:33 PM
Southern Utah
440Laser Offline
super street
440Laser  Offline
super street
Southern Utah
Try some Percy's gaskets. Cost a little more but will seal anything. Good luck.
Re: 440 exhaust flange gasket [Re: TrueTripleX] #103259
08/11/08 06:03 PM
08/11/08 06:03 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
Must be somethin` badly warped/wrong in there. That combo isn`t even supposed to have a gasket.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: 440 exhaust flange gasket [Re: TrueTripleX] #103260
08/11/08 06:05 PM
08/11/08 06:05 PM
North Texas
O
oleman Offline
oleman  Offline
O
North Texas
Everytime I have had problems with the flat flange exhaust pipes not sealing it has been warped flanges causing the problem. When the manifold is off the engine it would have been easy to flaten them with a belt or table sander.
I have never had much luck with silicone by on exhaust fittings but the high temp has a repetition for sealing.
The D-rings are a major improvement of flat seals but are only on later madels. I think the class a motorhome 440 used them. The truck engine.
There are some heavy metal flange reinforcers. That are supposed to squish warped flanges into shape. Oreilly did carry them but they require space around the current flange that you may not have.
