rear coil over shock question
#1032083
07/13/11 07:02 PM
07/13/11 07:02 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
ok, i have strange single adjustables on the back of my black junk it has a 12" 130 lb spring. i think that the shocks are not compressed enough and the rear is sitting a little to high. i am thinking the the shock will extend under launch and get maxed out. right now my shock eyes are 13". am i thinking about this right? i am also thinking that i need to change my springs for some 110s to put some adjustment into the rear susp. right now, any adjustment would be in one direction and IMO, the wrong direction also is there any weird science and how much lowing the rear will effect weight bias? and how is Quicktree doing? i tried calling him
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: rear coil over shock question
[Re: sixpackgut]
#1032084
07/13/11 07:22 PM
07/13/11 07:22 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You would be correct in using a lighter spring to get the design length... set the lower adjuster at 1" up from the bottom... with the correct spring you shouldnt have to adjust more than about 1" more to get the proper design length... to adjust ride height move the lower mounting point up or down...... cant say about Tony... I havent heard anything
[Re: MR_P_BODY]
#1032085
07/13/11 07:45 PM
07/13/11 07:45 PM
sixpackgut
Charleston
ok, thats good
[Re: Dyno1]
#1032087
07/13/11 09:43 PM
07/13/11 09:43 PM
sixpackgut
Charleston
A 12" rear spring should be compressed 3-4 inches. You are better off with a soft spring rather than a stiff spring because that will not allow the shock to work. The adjustment on the shock spring adjuster only changes the ride hight, not the shock settings. The shock will first entend on the launch.150 - .300", then go into compression .500 to .800 if everything is working correctly. If the car spins, you will have very little shock movement. Dyno
good info. thanks
[Re: Cab_Burge]
#1032089
07/14/11 01:36 AM
07/14/11 01:36 AM
Posts: 6,149 Melbourne , Australia
LA360
The 5.52" stroke (S5206) shock has a ride height range of 13.875" - 14.5", the 4.64" stroke (S5205) shock has a range of 12.625" - 13.25". These values are the shock length at ride height.
Alan Jones
