update on my car! #1028093
07/07/11 11:24 PM
07/07/11 11:24 PM
Freeport, Pa
W
whiskeyrunner Offline OP
W
Freeport, Pa
well after i let the car sit for 3 years..i finally got it done. just in time for the pittsburgh mopar race. i knew that the car would prolly go faster than 11.50s...so i had to slow it down due to no roll bar/cage. so i threw 110 lbs of weight in the car and disconnected the secondaries on the carb. first pass was 11.74. i was happy as heck! second pass was 11.64 and it stay right around there the rest of the day. well at the end of the day...my buddy got me a time pass...hooked up the secondaries...ditched the weight...launched at 3000 instead of 2000 and shifted at 6800 instead of 6000. the dang thing went 10.83 @ 122 mph! i couldnt believe it!
so heres a run down of the car.
70 duster-3300ish lbs.
360 small block cast crank
k1 rods with flat top srp pistons-11.5-1 comp.
ported eddy heads flowing 270 with harland sharps
racer brown 520 solid cam...forget the duration off hand
victor 340 intake-750 apd alky carb
904 trans and a 4500 stall 8 inch converter
4.30 pro gear with a 28 tall tire
3 inch exhaust into magnaflow straight thru mufflers dumping at the rear end
realistically the car is still a street car...just have to finish wiring the stock harness for lights and what not. now all i need to do is get a cage in the dang thing haha
Re: update on my car! [Re: whiskeyrunner] #1028094
07/07/11 11:37 PM
07/07/11 11:37 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Re: update on my car! [Re: whiskeyrunner] #1028095
07/07/11 11:49 PM
07/07/11 11:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just put a 6 point in it... thats good to 10.0
Re: update on my car! [Re: MR_P_BODY] #1028096
07/08/11 12:34 AM
07/08/11 12:34 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Mike he has a 12 point laying in the garage that I bought him for Christmas but he changed his mind and wants chrome moly now.
He wants to keep the rear seat so we would have to make a couple of custom bars.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: update on my car! [Re: pittsburghracer] #1028097
07/08/11 12:45 AM
07/08/11 12:45 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
It sounds like you are happy way to go running good is sweet so good luck. OH ONE MORE THING GO STEELERS
Re: update on my car! [Re: pittsburghracer] #1028098
07/08/11 12:51 AM
07/08/11 12:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I had alot more fun when I use to run 10.0 ... none
of the chassis cert and all the added safety equipment...
if he doesnt want to run 9.99 or quicker he doesnt
need all that cage ....... JMO
Re: update on my car! [Re: MR_P_BODY] #1028099
07/08/11 08:46 AM
07/08/11 08:46 AM
tboomer Online work
tboomer  Online Work
Congrats on getting it up and running!! And I agree with Mike..No sense in having the hassle to go quicker than 10.0...
Re: update on my car! [Re: tboomer] #1028100
07/08/11 09:32 AM
07/08/11 09:32 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
nice!
Re: update on my car! [Re: sixpackgut] #1028101
07/08/11 11:56 AM
07/08/11 11:56 AM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
NICE run!!!!!! Gives me hope cause my motor is close to yours and Ive been wondering what mine could run.
Re: update on my car! [Re: whiskeyrunner] #1028102
07/08/11 12:11 PM
07/08/11 12:11 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
good run!
Coming soon!!!!
Re: update on my car! [Re: whiskeyrunner] #1028103
07/08/11 12:18 PM
07/08/11 12:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s scootin.............nice car.
Re: update on my car! [Re: whiskeyrunner] #1028104
07/08/11 12:35 PM
07/08/11 12:35 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
..............' the dang thing went 10.83 @ 122 mph! i couldnt believe it!"
Of course it did. It's got a Racer Brown cam! Be carefull w/ overrevving, the same thing that makes that cam run hard will help it to self destruct. (Agressive lobes) I believe max recomended rpm is around 6500. What rocker ratio(int & exh) you run w/that?
Yeah, it's got a smallblock.
Re: update on my car! [Re: 340B5] #1028105
07/08/11 12:52 PM
07/08/11 12:52 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I'd suggest selling the 8 point and using the fuds to do subframes and a custom fitted bar that will allow seating and pass for 10 point ohs.
Re: update on my car! [Re: RodStRace] #1028106
07/08/11 01:03 PM
07/08/11 01:03 PM
gregsdart Offline
gregsdart  Offline
Street strip NA 10 sec small block? Very cool!
Whats great is, you haven't even got it sorted out yet!
Re: update on my car! [Re: gregsdart] #1028107
07/08/11 03:36 PM
07/08/11 03:36 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice running combo Is this a production 360 crank?
Re: update on my car! [Re: whiskeyrunner] #1028108
07/08/11 05:12 PM
07/08/11 05:12 PM
Pittsburgh
ChuckT Offline
ChuckT  Offline
Pittsburgh
But you're still a schmuck!
From 6/25 at PRP, time trials (so you can ignore that red eye!)
Re: update on my car! [Re: ChuckT] #1028109
07/08/11 08:40 PM
07/08/11 08:40 PM
Freeport, Pa
W
W
Freeport, Pa
haha chuck...that red eye was a -.004 thanks for the compliments...it was breaking up a little on that pass so i know theres more in it. its a stock cast crank motor..rocker ratio is 1.5 i believe on both ex and intake. i have a set of 1.6 ratios to try on the intakes tho. my plan is to sell the 10 point and go chromoly 12 point...leaving everything stock. i hate gutted out race cars lol so the back seat will be staying. why lose weight to go faster when all you have to do is build a good combination small block! future plans for the car is a 9 inch...leaving the caltracs tho cause it 60 footed a 1.46 on the 10 pass. tubular front end also...maybe a bondo bob piece! the car is on alcohol with an aeromotive a2000 pump and aeromotive regulator. hopefully i can get this thing in the winners cirlce being my only win came outta a chevy! lol any other questions..ill be more than happy to answer!
Re: update on my car! [Re: whiskeyrunner] #1028110
07/08/11 08:47 PM
07/08/11 08:47 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
you're not out rippin' up the streets in freeport with that are you? lol. that thing is movin. great job!
Re: update on my car! [Re: whiskeyrunner] #1028111
07/08/11 08:54 PM
07/08/11 08:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Because a lighter car is easier on parts and you dont
have to spent big money on power
Re: update on my car! [Re: Uncle Barry] #1028112
07/08/11 09:08 PM
07/08/11 09:08 PM
PA.
"Little"John
"Little"John
PA.
I think he planes to have it inspected soon Barry. He ran some 10.20's with that same engine on 93 octane last year in my Duster with a 727 trans but my car only weights 2500#. Hey Barry I took a ride past the old Nu Bee Dragstrip today. Hard to believe that 35 years ago I was racing my 72 Duster down those lanes.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
