Default 800HP streetable V10 combo? #1025674
07/04/11 11:43 AM
07/04/11 11:43 AM
Germany
1964Polara Offline OP
Germany
Our supercharged stock V10 was blown. So want to rebuilt it from Oil Pan to Head. Goal is streetable 800HP.....natural aspirated if possible?
Looking for a Stroker-Kit to start with new crank etc. to have a rock
solid base. Which performance Heads are out there? Turbo, Blower or ProCharger what are your thoughts?
Thanx
Re: Default 800HP streetable V10 combo? [Re: 1964Polara] #1025675
07/04/11 04:42 PM
07/04/11 04:42 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Truck or Viper?
Re: Default 800HP streetable V10 combo? [Re: Snoopy] #1025676
07/05/11 03:42 AM
07/05/11 03:42 AM
Germany
Germany
Truck or Viper?
2006 Viper!
Re: Default 800HP streetable V10 combo? [Re: 1964Polara] #1025677
07/05/11 04:02 AM
07/05/11 04:02 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
What broke in the last supercharged one?
Re: Default 800HP streetable V10 combo? [Re: autoxcuda] #1025678
07/05/11 08:58 AM
07/05/11 08:58 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I don't know that anyone is making a stroker crank for the V-10s. maybe a custom built one, or take a stock one and have it off-set ground?
port the stock heads, custom cam, etc. 800 hp is do-able from the motors, but keeping it NA might make it challenging. that's 300 more than stock.
**Photobucket sucks**
Re: Default 800HP streetable V10 combo? [Re: autoxcuda] #1025679
07/05/11 09:03 AM
07/05/11 09:03 AM
Germany
Germany
One Piston failed, Bolt moved and now its stucked in the cylinder wall...will see it personally this evening....Unsure if cylinder sleeves will handle so much power.
Re: Default 800HP streetable V10 combo? [Re: 70Cuda383] #1025680
07/05/11 09:06 AM
07/05/11 09:06 AM
Germany
Germany
Yes I know...do you think it will be stable to go with the old Paxton Unit if we use forged crank, Rods & Pistons and a custom cam? Otherwise
we where considering a Turbo setup to get load off from the crankshaft.
Re: Default 800HP streetable V10 combo? [Re: 1964Polara] #1025681
07/05/11 09:47 AM
07/05/11 09:47 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
there's some stupid power being made out there on the V10 blocks. twin turbo set-ups, nitrous, etc. 1200-1500 hp stuff.
but, I don't know what all they've done. for boost I would definitely look for all forged parts, are the stock parts not forged?
Re: Default 800HP streetable V10 combo? [Re: 70Cuda383] #1025682
07/05/11 04:07 PM
07/05/11 04:07 PM
Up North eh'
Stroked_Hemi Offline
Up North eh'
The most popular Viper head guy is Greg Good 713-290-1103, has a website, but nothing on it.. http://www.greggoodracing.com/ just google Viper Greg Good heads, numerous posts & info out there, also see Pro Line Racing, they stroke the V10s, scroll down http://prolineracing.net/latest-news/blog/page-18
Cheers,
Mike
Re: Default 800HP streetable V10 combo? [Re: 1964Polara] #1025683
07/05/11 04:09 PM
07/05/11 04:09 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
Thanx
Stroker Motor Parts - Viper Alley - Dodge Viper Forum link did not work call these guys 512-257-0222 they make stroker kits from 522 -600 plus inches for vipers,they grind the cranks,custom cams,rods,offset pistons ect.. email is portpros@sbcglobal.net
MOPAR OR NO CAR
