Re: 383 build for daily driver. Power/fuel mileage
[Re: HYPER8oSoNic]
#1025462
07/04/11 10:15 AM
07/04/11 10:15 AM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
A 528 solid cam is not going to be very street friendly in a pump gas 383. It surely won't get decent mileage. Talk to the cam grinders. They can come up with a better and more modern grind than that old MP stick.
[Re: Mr.Yuck]
#1025463
07/04/11 01:27 PM
07/04/11 01:27 PM
Posts: 4,930 Tri-Cities, Washington
VITC_GTX
I have to say that I am confused. I never would have thought a solid cam with that much lift and duration would work well at all for my needs. I have a 284/484 cam in my 440 and it has no vacuum and a very choppy idle and poor fuel mileage. I guess I just don't understand cams well enough... ![](/ubbthreads/images/graemlins/shruggy.gif) I was thinking something a little less money on the pistons as well. Any others have cam/piston suggestions?
[Re: VITC_GTX]
#1025464
07/04/11 01:38 PM
07/04/11 01:38 PM
Posts: 1,565 tennessee
pushbutton
tennessee
Comp XE-268 ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: VITC_GTX]
#1025466
07/04/11 01:58 PM
07/04/11 01:58 PM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
Looking to rebuild the 383 for my ’71 SSP. I want this car to be a daily driver with A/C so pump gas, good vacuum and decent fuel mileage is a must (I know not to expect much on fuel mileage but I would like to get 15+ mph if possible). In fact, I don’t want too much horsepower (is that possible?) because if I have it I will want to use it!!! Heads will be stock 906's.
Thinking of a stock-ish engine build but was hoping to take advantage of newer technology. What do you suggest for a decent build (pistons, cam, carb & manifold)?
If your running HP manifolds you might run the Comps 275DEH like i'm using 235/482 it pulls 12" of vacuum at idle with power brakes. Use the KB400 pistons, mill the heads .030 to get you around 84cc. Maybe a 670 street avenger carb (i'm using a 3310 750), you should be pretty happy and still get decent mileage if you keep your foot out of it . I'm running 3.91's now, you might want to use 3.55's or less for mileage.
[Re: ireland383]
#1025467
07/04/11 02:11 PM
07/04/11 02:11 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Fuel economy = short duration, low lift cam and small carburetor. I have a Crower 267/271 cam in my 383 which is close to the stock 4 bbl cam which is good for performance but not for economy. Look at their Baja Beast or maybe the Mileage Compu-pro cam. 250ish duration (200 at .050),.420ish lift and 112 centerline. I would go with a 500 cfm 4bbl for the ultimate in mileage. When gas wasn't garbage, a friend of mine could get 20 mpg highway out of a 440 with that combination.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: herkamer]
#1025469
07/04/11 03:13 PM
07/04/11 03:13 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
If fuel economy is more important than performance, this sounds like very good advice. Probably have very nice low end response too.
[Re: VITC_GTX]
#1025470
07/04/11 09:26 PM
07/04/11 09:26 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
284/484 cam is awful for anything but racing. The 528 solid is way more mild. Solid doesn't = Race. I'd think a well tuned 383 w/ a 528 solid with Mani's or headers and 3.23's would get at least 16 probaly more... That said If mpg's is what you are after I'd call a cam guy and have a cam made for your application
