Any problems with #1106 FelPro hemi head gaskets? #1025041
07/03/11 10:28 AM
07/03/11 10:28 AM
Chicago Il.
scatpac426 Offline OP
Chicago Il.
I'm in the final stages of assembling my engine and am alittle concerned about the head gaskets. I have been seeing alot of problems guys are having with oil and coolant leaks from the heads. So my question is are #1106 head gaskets ok? Should I put any sealer around the oil and water openings of the head gasket?
Re: Any problems with #1106 FelPro hemi head gaskets? [Re: scatpac426] #1025042
07/03/11 10:38 AM
07/03/11 10:38 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I use the 1105 (440 .051 thick ) and they are fine as is as they are composition gaskets. make sure everything is nice and clean and no problems.
Re: Any problems with #1106 FelPro hemi head gaskets? [Re: scatpac426] #1025043
07/03/11 12:38 PM
07/03/11 12:38 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If both the block and head surface are square you shouldn't have a problem with any head gasket.
