A body 8 3/4 Rear
#1022591
06/29/11 10:35 AM
06/29/11 10:35 AM
Posts: 3,288 Stroudsburg, PA
Erik
Stroudsburg, PA
I saw a post here a few weeks ago on A-body rears and now I can't find it.
Anyway, how can I tell what year rear I have (it's not original to the car) so that I get the right brake lines for it?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: A body 8 3/4 Rear
[Re: Erik]
#1022592
06/29/11 10:46 AM
06/29/11 10:46 AM
Posts: 15,487 Florida
scratchnfotraction
the ring gear will have the yr and gear ratio stamped in it. as far as a housing goes,check the BOM stamp on the housing. ar you sure it is an A-body housing? maybe a B-body housing? maybe a cut down housing? may be best to ben up you own lines for it,I did when I had a c-body housing cut down to A-body specs.
[Re: Rhinodart]
#1022595
06/29/11 11:03 AM
06/29/11 11:03 AM
Erik
Stroudsburg, PA
It's an original A-Body rear with the small bolt pattern 9" drums. All of the old lines are still on it, so I can get pics/details when I get home tonight.
3.23 sure grip 741 case.
[Re: Erik]
#1022598
06/30/11 11:10 AM
06/30/11 11:10 AM
Erik
Stroudsburg, PA
What are the measurements for the different years?
[Re: JohnRR]
#1022600
07/11/11 04:18 PM
07/11/11 04:18 PM
Erik
Stroudsburg, PA
Well, I went out to Carlisle and got the 70 up brake lines. Nope, don't fit. Looks like I do have the earlier one.
[Re: mopar4ya]
#1022605
07/12/11 01:36 AM
07/12/11 01:36 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Did the location of the block change when they went to the big bolt pattern??
Dan.
No it changed in 1970 , as stated there were no A body large bolt pattern rears except maybe on the 68 SS cars .
I have a 70 up rear apart in the basement, the bolt hole for the Tee is approx. 15.75" from the surface the backing plate bolts to. Erik , the rear you have is definitely the early rear ... sorry
[Re: DoctorDiff]
#1022607
07/12/11 10:57 AM
07/12/11 10:57 AM
Erik
Stroudsburg, PA
No problem, John. Not a big deal.
