318 NON ac water pump pulley #1022445
06/29/11 12:34 AM
06/29/11 12:34 AM
St Louis, Mo USA
Wagonmaster'79 Offline OP
St Louis, Mo USA
I would like to take all the ac stuff off my '79 Aspen,is there a water pump pulley that is for a non ac application?Also would I need a brace from the upper alt bolt to water pump correct?Sorry,it's a 318
Thanx
Ronnie
My reading of history convinces me that most bad government results from too much government - Thomas Jefferson.
Re: 318 NON ac water pump pulley [Re: Wagonmaster'79] #1022446
06/29/11 09:11 AM
06/29/11 09:11 AM
scratchnfotraction Offline
you will need the pulley set from a non a/c engine..crank and wp
you will also need the non a/c alt brackets
you can remove the a/c comp and put the brackets back on,then run a belt from the crank to the alt bypassing the a/c comp
you can remove the triangle piece thats on the neck of wp and run 2 belts right off the crank to the wp.
just cut and file flat,both belts will fit...or just use the front groove only.
you can leave all the a/c stuff in place and just run the belts from crank to alt also.
if you go to non a/c pulleys,you should step the wp up to the 8 vane wp to keep the ratio and pump flow correct,IMHO
IIRC a ps belt or one close to that size fits from crank to alt to bypass it.
