Re: launch issues ( update )
[Re: Mick70RR]
#1022179
08/01/11 06:08 PM
08/01/11 06:08 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Cheers Mick Well done on your first 11, i saw you run but not the 11 unfortunately, will perhaps ring you this week, to see how your weekend went. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: roadhazard]
#1022181
08/01/11 06:12 PM
08/01/11 06:12 PM
deaks
robin hood country
Thanks Greg If i could match your 60 ft maybe a high 10.1, that's if the moon and the stars all align at the same time. Mick
[Re: tboomer]
#1022183
08/01/11 06:29 PM
08/01/11 06:29 PM
deaks
robin hood country
Thanks Ted Just another thing worth mentioning, on one of my runs in the hotter part of the day, i switched my fan and water pump off during the run and with a slower et, it matched my best speed of the weekend, over 129. Mick
[Re: deaks]
#1022184
08/01/11 10:09 PM
08/01/11 10:09 PM
Posts: 3,456 Out West
408strokerdart
Out West
Fan off = ok, water pump off = not ok ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 408strokerdart]
#1022185
08/02/11 04:56 AM
08/02/11 04:56 AM
deaks
robin hood country
Ok, maybe just fan in future, it only hit 180 at the end though. Mick
[Re: 493_DART]
#1022187
08/02/11 05:31 AM
08/02/11 05:31 AM
deaks
robin hood country
It was not without pain though, as i broke the nose off the starter, which is the second time now in 6 mths. I suspect it's the ring gear on the converter, when it was delivered, the box had been dropped and it had a flat on one side which i managed to pull out but there was also a slight bend the other way, which I think is causing a buckled wheel effect. Thanks Kevin, have pm'd you. Mick
[Re: deaks]
#1022188
08/02/11 09:41 AM
08/02/11 09:41 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
![](/ubbthreads/images/graemlins/iagree.gif) with 408strokerdart I turn my fan OFF just before I pre stage. The water pump needs to be running to help eliminate any hot spots in the heads or block. Last time out with my car 60' results Best 1.389 Worst 1.417 Average (6 passes) 1.4065 Difference .028 over 3 days/nights Most of the inconsistency was the driver not staging the car the same ![](/ubbthreads/images/graemlins/spank.gif) That's what I get for being a keyboard racer ![](/ubbthreads/images/graemlins/frown.gif)
[Re: roadhazard]
#1022189
08/02/11 06:33 PM
08/02/11 06:33 PM
deaks
robin hood country
Pic of one of my runs last wk. Mick
[Re: cudadon]
#1022191
08/02/11 08:08 PM
08/02/11 08:08 PM
deaks
robin hood country
How go's it Don I dont think i can match your times with it but maybe a high 10.1 if i'm very lucky. Mick
