offset upper control arm bushings for radials
#1020043
06/25/11 03:38 AM
06/25/11 03:38 AM
Posts: 49 alaska
69 mayflower
alaska
I read this in a previous thread and have never heard about offset bushings,so I have questions.It was said that Moog part #K-7103 bushings were used to increase positive caster in order to run radial tires.Why is positive caster required?My car is a '69 Plymouth B Body,the car in the previous thread was a '71 B Body.I'm assuming that since they used the same UCA that the same offset bushing would be used.Is this correct?I will be rebuilding my front suspension very soon and will be running radials.This is a rotissourie restoration and am curious if I install the offset bushings,can I still run bias ply tires,should I need, for factory correctness.One other question is,do I use the same alignment bolts?
1969 Plymouth Sport Satellite 383
1990 Dodge W150 plowtruck 318
2012 Dodge Ram 1500 4WD 5.7 HEMI
2012 Dodge Challenger R/T Classic Blackberry Pearl 5.7 HEMI
MOPAR- WHAT ALL OTHER CARS WANT TO BE WHEN THEY GROW UP-
Re: offset upper control arm bushings for radials
[Re: ahy]
#1020046
06/25/11 08:30 AM
06/25/11 08:30 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Just dont install them as per the instructions.Mopars they get installed backwards.Rocky
Chrysler Firepower
[Re: therocks]
#1020047
06/25/11 02:39 PM
06/25/11 02:39 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The Moog bushings in question were not designed for radials or anything other than to "fix" a sagging front end that prevented you from getting correct camber.
What people use them for is another thing.
First time I ever heard the radial claim you mentioned, I've never run the Moog bushings and I have run radials for 30+ years on my old Mopars with no issues.
[Re: TC@HP2]
#1020049
06/28/11 03:11 PM
06/28/11 03:11 PM
therocks
Niles , Ohio
You can get a Mopar frt to sit as high or low as you want with the Tbars.They were designed for bias tires and after 40 years the specs dont cut it with radials.Most will have neg caster and positive camber.Not great with radials.I do my own alingments and have been doing they for 30 years.Ive had very few Mopars that I could get the caster to positive without the bushings or asjustable upper arms.Rocky
Chrysler Firepower
