Re: aluminum radiator and fan for A body [Re: megajoltman] #1018738
06/24/11 12:50 AM
06/24/11 12:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Hey guys how thick are the 28x19 triple pass radiator?
They are 3 times as thick!
No reason for them not to be about the same thickness as normal rads.
If I need to buy again ,it will be a triple pass.
I had heard the tank and core was thicker
No reason for it to be thicker... when they say PASS
the tanks have a couple of baffles that makes the
water travel back and forth in the core(triple passes
3 times in the core) basically the core is in 3 sections...
if you look down the cap opening you will see a baffle
Re: aluminum radiator and fan for A body [Re: stroked470] #1018739
06/24/11 08:44 PM
06/24/11 08:44 PM
pro99 Offline
pro99  Offline
Does anybody have that part number for the Summit 29x19 or is it the 28x19 3 row radiator to fit in a 68 Dart body? Also is there a part number on fans that will bolt up to them?
1968 Dart Drag Car (I just bought it)
