brake drums on a 68 Chrylser???? #1017590
06/21/11 09:34 AM
06/21/11 09:34 AM
Lost and Spaced
bboogieart Offline OP
Lost and Spaced
I am doing a complete brake job as the car has sat for years and a new motor and trans are going in. My question is this; one brake drum had three weights on it the three others have none. Were the drums balanced individually or is this balance for the rear axle. Can I put back on any where or is it specific to it's origanal location? Obviously I am asking because I don't remember witch side it came off of. Doh. Here is a pic of the drums in question. the arrow points to the weights.
Also will sand blasting warp the drums. I have cleaned the scale off with a wire wheel and want to blast them for the best paint adhesion.
Thanx all for your help.
Re: brake drums on a 68 Chrylser???? [Re: bboogieart] #1017591
06/21/11 09:47 AM
06/21/11 09:47 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
just a balance weight for the drum itself,some have it some don't and it'll go on either side just fine.
Re: brake drums on a 68 Chrylser???? [Re: gtx6970] #1017592
06/21/11 09:52 AM
06/21/11 09:52 AM
Lost and Spaced
Lost and Spaced
Whew Thanx alot That one must of been off the jig when it was welded. OK now back to the garage.
