How much powder coat should I order from Eastwoods? #1016967
06/20/11 03:05 PM
06/20/11 03:05 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I will be powdercoating the lower and upper control arms, end link rods, drum brake backing plates, spindles, and rearend shock mounts, rear leaf spring mounting bracket, and a few other odds and end pieces. I have never had powdercoating done before; I want to use cast gray for these pieces so I will have to order the powder for the shop to use. How much should I order? Thanks
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: How much powder coat should I order from Eastwoods? [Re: 70B5Cuda] #1016968
06/20/11 09:10 PM
06/20/11 09:10 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I say it can be done with 5 lbs, but best to have 10 lbs on hand, just incase,.. depends on the guy spraying,....IIRC Eastwood will accept powder return if the bags aren't open
