Re: 130lbs cranking pressure ???? [Re: 440Jim] #1016172
06/21/11 06:03 PM
06/21/11 06:03 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
OK wich way were you off? Was the cam retarded?
I have went behind people who installed a camshaft advanced. And add insult to injury did it on a stock suspension car running street tires. Car would just blow the tires off. Then it would not MPH on the big end at all when it did hook. One guy wanted to run nitrous so I checked cranking compression. Small roller high compression small block. The thing had 270 PSI. Rediculous. So I retarded the cam and got it down closer to 200 psi, which turned out to be degreed where the manufacturer suggested to begin with. We drove it a little before spraying. The guy debated about not spraying it at all because the car actually hooked and ran on the big end.
In a nutshell cam timing affects cranking compression. Some cams more than others.
Leon
Re: 130lbs cranking pressure ???? [Re: Leon441] #1016173
06/21/11 07:10 PM
06/21/11 07:10 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Thanks....
Do you know how much they expand when hot ? .004 ?
Dan
Re: 130lbs cranking pressure ???? [Re: MR_P_BODY] #1016174
06/21/11 09:10 PM
06/21/11 09:10 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
same piston and ring as last fall....
What did you degree the cam in at... sounds like its retarted
Re: 130lbs cranking pressure ???? [Re: moparmanjames] #1016175
06/22/11 02:19 PM
06/22/11 02:19 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Why does every one keep calling his cam names?
Re: 130lbs cranking pressure ???? [Re: HotRodDave] #1016176
06/22/11 10:44 PM
06/22/11 10:44 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
loll !
Thanks guys..
Dan
