Rustoleum paint job???? #1014457
06/16/11 05:14 PM
06/16/11 05:14 PM
Kalispell Mt.
HotRodDave Offline OP
Kalispell Mt.
Any one ever use the 1 galon cans at home de pot for painting a car? I know they are just a few colors to pick from but at $27 a can will it make a 1/2 respectable paint job on a $500 car?
Any tips for thinning it and spraying it? Does it need any primer if sprayed right on fresh bare metal? Reading the label seems no primer or clear is needed seems to be a cheap way to make a cheap car look ok for a couple years
Re: Rustoleum paint job???? [Re: HotRodDave] #1014458
06/16/11 05:21 PM
06/16/11 05:21 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
What I think would be FAR superior would be to source an industrial urethane or acrylic enamel. It's catalyzed, single stage easy to spray.
Here's an example: A gallon of acrylic enamel, with hardener and reducer, just over $75 for the whole kit. 144 different colors. That's hard to beat. Equivalent to Delstar or Centari.
web page
Back to your question, yes you do need a good sanded substrate (original finish or primer) to spray any paint product over. No you do not need clear. Yes, you have to reduce it, probably with mineral spirits (see the label on can). There is a Valspar brand hardener that works with implement enamel which may help with durability. It's just that I would not expect a household uncatalyzed paint product like Rustoleum to hold up to much UV exposure. Yeah, yeah, I know you can roll it on and work with it on the cheap. For not all that much more, I'd just buy some real paint to spray.
Re: Rustoleum paint job???? [Re: HotRodDave] #1014459
06/16/11 05:48 PM
06/16/11 05:48 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
There was a huge post on here a couple years ago about "paint job on a budget" and I think 69Dart used Rustoleum and a foam roller to paint his truck. I didn't follow it closely, but I think the results were a nice quick finish, but didn't hold up well in the sun. Somebody will have a link on here.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Rustoleum paint job???? [Re: GO_Fish] #1014460
06/16/11 05:54 PM
06/16/11 05:54 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
Here is the link to the old thread.
Paint job on a Budget
The only advantage I can see to the foam roller method is if your situation prevents you from spraying paint. Otherwise it is VERY labor intensive. Do you really want to roll on and wet sand several coats of paint, when you can spray some acrylic enamel and be DONE.
Re: Rustoleum paint job???? [Re: GO_Fish] #1014461
06/16/11 05:56 PM
06/16/11 05:56 PM
NY NY
3
340duster340 Offline
NY NY
Why not just take it to maaco? My uncle had his car painted there and it looked great...considering it only cost 300
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: Rustoleum paint job???? [Re: 340duster340] #1014462
06/16/11 05:59 PM
06/16/11 05:59 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
That may be an option. Preparation on your end is key. As Maaco is franchised, results may vary.
Re: Rustoleum paint job???? [Re: HotRodDave] #1014463
06/16/11 07:32 PM
06/16/11 07:32 PM
scratchnfotraction Offline
I used a gallon of rustoleum to paint all the black on my truck
after sand blasting,I painted the frame,rear axle,underhood,core support,inner fenders,inside of cab,door jambs
used the satin black on the hood,cowl,letters on the gate
used regular laquer thinner and used a HVLP set up and only used 1 gallon of the gloss and 2 quarts of satin
I used 1 gallon of 2k primer,and 1 gallon of 4th deminsion bright lemon yellow,with 2 gallons of clear coat and the thinner that goes with it.
it turned out real nice on the black and satin and the 2 stage paint worked well also,painted it outside in the back yard,and to my surprize it did not get a lot of crap in it,had about 4 runs in the clear that sanded out after it was dry,was my first try at bodywork and paint..well my buddy did the bodywork and shot the paint,I bank rolled it and did the labor... so it was we when I say I
i just either sandblasted stuff and shot it or scuffed it with a pad useing the black,exept the body work,that got 80,150,320,400 wet
I can post some pics if you want a looky see at the black inside of cab and the rest of it
you can order hemi orange in rustoleum too,thats what I should have painted the engine with,but I used the plasticoat hemi orange.
Re: Rustoleum paint job???? [Re: HotRodDave] #1014464
06/16/11 09:03 PM
06/16/11 09:03 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
The current issue of Hot Rod has a article on a Rust-Oleum flat black paint job.Check it out.
Re: Rustoleum paint job???? [Re: pushbutton] #1014465
06/16/11 10:11 PM
06/16/11 10:11 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Good article.
Re: Rustoleum paint job???? [Re: pinkduster] #1014466
06/17/11 01:48 AM
06/17/11 01:48 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Go to autozone and check out their options of rustoleum and i think it was dupont. They sell ready to spray quarts of laquer. You can also get a gallon of primer sealer for $45 and the thinner for $18. You can also buy paint from summit racing ready to spray as well for cheap.
Re: Rustoleum paint job???? [Re: None2Slow] #1014467
06/17/11 07:48 AM
06/17/11 07:48 AM
IN
ahy Offline
ahy  Offline
IN
I've sprayed it on trailers and other equipment. It sprays well and makes a nice finish. Reduce 10-15% with paint thinner and have at it. Two light/medium coats 20-30 minutes apart work best. I always prefer to use a primer. Rustoleum red "damp proof" primer works well. Same deal on spraying. Thin 10-15% and two light/medium coats. The damp proof primer takes a day or more to dry. Sun and wind can speed this up a lot. When thoroughly dried, it is easy to sand.
Two drawbacks to be aware of. Because of slow drying, it will likley pick up bugs/dirt. With care it won't be a big deal. Also it hardens slowly. It will be tender for a while. Again, sun/wind helps after the initial dry.
Re: Rustoleum paint job???? [Re: ahy] #1014468
06/17/11 08:12 AM
06/17/11 08:12 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
in the paint job on a budget thread, another option (if you have a west marine near you--we have one down the street, but you might not in montana is interlux brightside boat paint
http://www.yachtpaint.com/usa/diy/products/finishes/brightside-polyurethane.aspx
it's basically a single stage urethane that can be brushed, rollered, or sprayed, and very good results have been done with the roller. I may try it once my duster gets ratty enough....Y4381 off white looks very close to my EW1 spinnaker white
2017 Grand Cherokee Overland
Re: Rustoleum paint job???? [Re: patrick] #1014469
06/17/11 01:07 PM
06/17/11 01:07 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Couple years ago I got a big display cabinet out of a business that closed up. The sides were a nasty salmon color. I used Rust-Oleum gloss black and I reduced it with mineral spirits. I think I went two parts paint and one part reducer. Sprayed it with a cheap old style paint gun and it came out great, but it did dry slow.
Re: Rustoleum paint job???? [Re: pinkduster] #1014470
06/17/11 01:16 PM
06/17/11 01:16 PM
Pennsylvania
scannman70 Offline
scannman70  Offline
Pennsylvania
I used paint from tractor supply on the snow commander.
About the same price as rustoleium.
Make sure to use the hardner, other wise it will fade in the sun..
Mine is holding up great!!
Re: Rustoleum paint job???? [Re: patrick] #1014471
06/17/11 04:13 PM
06/17/11 04:13 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
That looks interesting. I could paint my fiberglass motorhome with that. It's white with two accent colors.
Re: Rustoleum paint job???? [Re: NicksGarage] #1014472
06/17/11 05:40 PM
06/17/11 05:40 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
My Rusto experience:
Several years ago I did a loose fender and then a whole car with the ‘moparts’ roller method. Results on fender were decent, result on whole car was crap (but at least it became 1 color).
Last July I did a whole car, and then also painted a loose door and clearcoated it with Rusto’s clearcoat. Followed that with wetsanding and buffing.
On the car:
We spent about 2 weeks of evenings filling dents and removing all the trim, mirrors, doorlocks and handles, etc. Lots of primer, lots of sanding. Sprayed in indoors in a home-made spraybooth. It turned out OK, has about 3 coats of standard white gloss and has a mild shine. This is where I discovered Rusto does not fill all the sanding scratches. Why it will fill small paint chips, but not scratches, is a mystery to me. ??? Ideally we would have given this car 2-3 more coats and buffed it, but to be honest I was tired of working on the body and needed to get the car ready to drive.
This paintjob is almost a year old and has been driven thru an Indiana winter. It has held up pretty well, although it did chip away at both seams where the headerpanel meets the fenders.
On the loose door:
It turned out really nice, almost like glass, and if on a whole car would easily pass for a $5000 paintjob. I cannot speak for long-term durability of the clearcoat, however this door has been sitting out in my backyard, in the sun and rain, underneath some trees and bushes that drop lots of leaves and buds, for over a year. Whenever I wipe it with a soapy sponge I can tell that the gloss is still there. I have noticed that there are blemishes on it, perhaps from acid rain, and I suspect this is due to Rusto drying so slowly and it getting standing rain on it before fully dry. I think a hardener in the clearcoat might help. That’s a future experiment.
Overall –
With limited colors available in Rusto, and the difference in price vs car paint, it’s a toss-up. I’d say if you’re gonna spend a lot of effort on body prep then spend a little more $$ on cheap car paint. If it’s a beater and expense is crucial, Rusto is a decent option.
The experimenter in me wants to find a hardener for the clearcoat and try again, though.
Re: Rustoleum paint job???? [Re: Fury Fan] #1014473
06/17/11 05:42 PM
06/17/11 05:42 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
And the car...
Re: Rustoleum paint job???? [Re: Fury Fan] #1014474
06/17/11 05:44 PM
06/17/11 05:44 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
With its clothes on...
