TQ surging #1013432
06/14/11 07:19 PM
06/14/11 07:19 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I've got a big bore TQ on my 340 and at a slow steady cruise speed (some at highway speeds but not as bad) I get some slight surging and it seems every so often it sounds like it will die. It feels fuel related. Anyone?
Re: TQ surging [Re: JonC] #1013433
06/14/11 07:31 PM
06/14/11 07:31 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
GIVE the tree a turn or so CLOCKWISE .... it will raise the rods and give it another jet-size or two.
Re: TQ surging [Re: BeEtLeJuIcE !] #1013434
06/14/11 07:37 PM
06/14/11 07:37 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes, I agree, try richening the primary metering rod tree.
Re: TQ surging [Re: DaytonaTurbo] #1013435
06/14/11 07:40 PM
06/14/11 07:40 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Doing it now, then for a ride.
Re: TQ surging [Re: JonC] #1013436
06/14/11 07:50 PM
06/14/11 07:50 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Went around town (small town) and it seems to be worse with 2 turns CW.
Re: TQ surging [Re: JonC] #1013437
06/14/11 07:55 PM
06/14/11 07:55 PM
Florida STAYcation
Florida STAYcation
do you know what rods are in there ?
Re: TQ surging [Re: BeEtLeJuIcE !] #1013438
06/14/11 07:56 PM
06/14/11 07:56 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I have no idea.
Re: TQ surging [Re: JonC] #1013439
06/14/11 08:08 PM
06/14/11 08:08 PM
Florida STAYcation
Florida STAYcation
You might want to pull them out and check the "steps" in them ...
Re: TQ surging [Re: BeEtLeJuIcE !] #1013440
06/14/11 08:23 PM
06/14/11 08:23 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
What would I be looking for, a baseline?
Re: TQ surging [Re: JonC] #1013441
06/14/11 08:34 PM
06/14/11 08:34 PM
CW raised the tree right? Might go a bunch more turns & if that helps, it confirm (or deny) that it's a lean prob which it sure sounds like classic lean
Re: TQ surging [Re: JonC] #1013442
06/14/11 08:39 PM
06/14/11 08:39 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Was it surging before the engine work? If it ran OK I would go back to where it was then maybe go 1/8th turn at a time and run it up the Golden road. Does the secondary air valve snap back into position if you tap the rear?
Re: TQ surging [Re: T2R9] #1013443
06/14/11 08:48 PM
06/14/11 08:48 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
It was doing it before the engine work, and the last time I took it up the Golden Road I broke a frame rail on the speed bump before Abol bridge, forgot it was there and had 5 people in the car. I'll do some more tuning tomorrow. I'll let you know what I find.
Re: TQ surging [Re: JonC] #1013444
06/15/11 01:00 AM
06/15/11 01:00 AM
Florida STAYcation
Florida STAYcation
Are you able to pull the rods out? .. there should be THREE STEPS in the rods ...at least most of them do. If you have the TWO STEP ones ..... that could be why you don't see any diff.
Re: TQ surging [Re: BeEtLeJuIcE !] #1013445
07/01/11 01:22 PM
07/01/11 01:22 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I have adjusted the tree every which way and no change, could the floats be high?
Re: TQ surging [Re: JonC] #1013446
07/01/11 05:02 PM
07/01/11 05:02 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i would open it up and check the floats, then set the height correctly
