'06 Caravan Rear Brake Hanging Up? #1011061
06/11/11 03:08 PM
06/11/11 03:08 PM
Not2farfromNashville, TN
Rug_Trucker Offline OP
Kind of what I am thinking is happening it sounds like it is releasing slowly. I was going to pull it apart and see where I can lube it to make it release quicker.
Or maybe it is caliper time?
Any thoughts?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: '06 Caravan Rear Brake Hanging Up? [Re: Rug_Trucker] #1011062
06/11/11 05:00 PM
06/11/11 05:00 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Hay RT ... is this a disc rear ? ... this does this during driving ? .. my 03 is hanging-up if it is parked more than 24 hours...
Re: '06 Caravan Rear Brake Hanging Up? [Re: dOrk !] #1011063
06/11/11 06:33 PM
06/11/11 06:33 PM
Disc rear. Going out there in a few.
It does it taking off from a stop, braking at slow speed coming off a corner etc.
Re: '06 Caravan Rear Brake Hanging Up? [Re: Rug_Trucker] #1011064
06/11/11 09:08 PM
06/11/11 09:08 PM
Looks like plenty of brake pad left. Piston looks like it is way extended. I don't have a book. Talking with IMGTX he said a Concorde he was working on needed almost 1/2" of material on each pad. I need an oil filter for the Cummins so I am going to go check some new pads at the store.
I coated the slides and the chrome plated pins with Neversieze for lube.
Re: '06 Caravan Rear Brake Hanging Up? [Re: Rug_Trucker] #1011065
06/11/11 09:12 PM
06/11/11 09:12 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Corroded piston in the bore of the calipher will do it.
