Page 1 of 3 1 2 3
Does anyone see ANYTHING wrong with these PICS ????? #1010976
06/11/11 01:46 PM
06/11/11 01:46 PM
Lake Charles,Louisiana
BILLYJAY Offline OP
BILLYJAY  Offline OP
Well pulled my Head this morning to change what i thought was just going to be a Valve from my last trip to the track. . and to my surprise i was AMAZED at what i saw..So i began to look alittle closer at the motor...Looks like my Race season is over before it began....
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: BILLYJAY] #1010977
06/11/11 01:47 PM
06/11/11 01:47 PM
Q
Quicktree Offline
Quicktree  Offline
Q
looks like a new canted valve design
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: BILLYJAY] #1010978
06/11/11 01:49 PM
06/11/11 01:49 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Once i started looking a bit closer to see what had happened.. this is what i found... OUCH !!!!!!!
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: BILLYJAY] #1010979
06/11/11 01:50 PM
06/11/11 01:50 PM
Q
Quicktree Offline
Quicktree  Offline
Q
really sorry to see that. hope you get it fixed soon
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: Quicktree] #1010980
06/11/11 01:52 PM
06/11/11 01:52 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
what rods are you using and what rpm where you reving at
1.39 9.85 - 137 mph
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: BILLYJAY] #1010981
06/11/11 01:57 PM
06/11/11 01:57 PM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: BILLYJAY] #1010982
06/11/11 01:58 PM
06/11/11 01:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well at least its a alum block and you can glue that
back together.... bummer
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: MR_P_BODY] #1010983
06/11/11 02:07 PM
06/11/11 02:07 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
Ohio crank and K-1 h-beam rods, was only spinning the motor at 7-7200 at WOT, but when it happened i had just installed the new tunnel ram and had made a nice burnout then staged and left the line at only 3400 on the Brake and got about 300 fett out when the car shook and i shut it down... checking in the pits, i found a lash cap off of #1 cylinder and tried to reset it and still had a dead spot, so havent done anything to the car in months waiting to have time off from work to pull the head and change the one valve i thought was bent.. this is what i found when i pulled it...
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: BILLYJAY] #1010984
06/11/11 02:19 PM
06/11/11 02:19 PM
Q
Quicktree Offline
Quicktree  Offline
Q
bet you over reved it in the burn out box, seen it happen before just like that
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: Quicktree] #1010985
06/11/11 05:16 PM
06/11/11 05:16 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
i dont think i have ever over rev'd the motor..i have a 7500 chip in the tall side of my 7al box and have never banged against it..But, who knows.?? i will tear it down and see when i get time.. i am betting it was a bearing failure that led to this..just a Guess though..
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: BILLYJAY] #1010986
06/11/11 05:22 PM
06/11/11 05:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what kind of rod bolts? I see you said it didn't hit the limiter
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: Quicktree] #1010987
06/11/11 07:15 PM
06/11/11 07:15 PM
BILLYJAY Offline OP
BILLYJAY  Offline OP
http://www.k1technologies.com/Rods/tabid/57/Default.aspx
Forged 4340 Steel I Beam connecting rods. Shot peened for improved fatigue life. Sizes held to +/- .0001” , finish honed in the USA. Bronze wrist pin bushings. Weight matched +/- 1 gram on each end. Exclusively using ARP fasteners.
Billet 4340 Steel H Beam connecting rods. Closely monitored material mechanical properties for optimum performance. Designed and finish honed in the USA. Sizes held to some of the tightest tolerances in the industry, +/- .0001” and +/- 1 gram per end. Shot peened for improved fatigue life. Bronze wrist pin bushings. Exclusively using ARP 2000 fasteners.
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: BILLYJAY] #1010988
06/11/11 07:39 PM
06/11/11 07:39 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Those are decent rods and great fasteners. Its got to be a rod bearing/spun failure as you have surmised.
I think the bearings weak link is the OE little tabs that secure them in. I think they should all be pinned in. As is when they see a little extra friction from lack of oil and they spin.
If they stade in place we would just see some bearing damage and not broken rods and blocks and everything else that can occur.
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: Sport440] #1010989
06/11/11 08:39 PM
06/11/11 08:39 PM
Guitar Jones Offline
The tabs do not hold the bearing shells, it is only the crush that keeps them in place. The tabs are for locating only.
Lack of oil can cause a bearing to spin but more likely what happens is the big end of the rod gets eggshaped at RPM and the bearing bites the journal and then it's all over but the crying.
Sorry to hear about you problem, that's got to hurt.
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: Sport440] #1010990
06/11/11 08:42 PM
06/11/11 08:42 PM
gregsdart Offline
gregsdart  Offline
Bummer! I hope the damage is minimal! Sorry to here about it.
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: gregsdart] #1010991
06/12/11 09:05 AM
06/12/11 09:05 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Were these the rods that had been clearanced in the rod bolt area? Any pics of the internals?
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: BILLYJAY] #1010992
06/12/11 09:23 AM
06/12/11 09:23 AM
NC
chris3 Offline
chris3  Offline
NC
This looks and sounds like an all too familiar sight and description. "broken K1 connecting rod and a torn up block" and that picture of the piston sure looks familiar. Please let me know what you find when you take the pan off and start removing the rods.
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: BILLYJAY] #1010993
06/12/11 09:58 AM
06/12/11 09:58 AM
NC
440Jim Offline
440Jim  Offline
NC
Ouch. That hurts to see happen.
Keep us posted on what you find when you get the short block apart.
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: BILLYJAY] #1010994
06/12/11 10:03 AM
06/12/11 10:03 AM
ill
dennismopar73 Offline
ill
surprized you are using felpro blue head gasket? close up shows gasket leak comp on # 1 ?? , wouldnt use those except on street motor ,
did the cam get wiped out in the carnage as well?? appears that # piston hit a valve,
does appear that it lost bearing ,? oiling issue??
sorry for this , at least it is repairable all is not lost,
Re: Does anyone see ANYTHING wrong with these PICS ????? [Re: chris3] #1010995
06/12/11 10:14 AM
06/12/11 10:14 AM
Q
Quicktree Offline
Quicktree  Offline
Q
where did you get that info from? I haven't heard of many K1 rods failing?
Page 1 of 3 1 2 3
