Re: Why won't my alternator charge?
[Re: dennismopar73]
#1010072
06/12/11 08:44 PM
06/12/11 08:44 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
by the way NICE CARS!!
Thanks, I only own the purple Dart, our good buddy Rob(Dartman928) owns the sweet Lime Green rig.
I found 2 small problems, the wire going from the alternator to the back of the car is only 10 gauge, so that needs upgraded to a 4 or 6. And that is also why the alternator gets 14.7 and the battery only gets 13.8.
Also, I hooked my hand held voltmeter up to the back of the cheapo Summit Racing volt gauge in my car and it reads 13.8 when the car is running, so it appears to just be a bad gauge.
Time to run a bigger wire and install a new gauge. The car ran sweet all weekend.
[Re: ProSport]
#1010073
06/12/11 08:52 PM
06/12/11 08:52 PM
Quicktree
#8 wire will work if the run is 12' or less but #6 wouldn't hurt and #4 is overkill still make sure you have good grounds everywhere.
[Re: ProSport]
#1010075
06/12/11 11:33 PM
06/12/11 11:33 PM
Posts: 2,792 IN
Dartman928
IN
Bob, How do you have all your grounds ran in the car? What gauge do you have for grounds? Hope you get it all figured out
[Re: ProSport]
#1010077
06/13/11 04:58 PM
06/13/11 04:58 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I ran #4 from the alternator to the cutoff switch..100 amp alternator and it charges great.
[Re: Dartman928]
#1010078
06/13/11 10:56 PM
06/13/11 10:56 PM
ProSport
Akron, Ohio
Bob,
Rob, I seem to have grounds all over the place, everything is running fine, I just didn't like how the gauge only read 12.5 but it appears to be a bad gauge. I'm gonna get a new gauge and install a larger alt wire.
Rob how do you have yours grounded?
