1995 Dodge Stratus Transmission filter change ? #1009927
06/09/11 11:03 AM
06/09/11 11:03 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I have a 1995 Stratus with the V6 an auto transmission with 130,000. I thought I would change the tranny fluid and filter. Is this something that can be done at home? Do you just drop the pan, and unscrew filter and reverse with new stuff (like a 727)?
Any input would be appreciated.
How much fluid do you add after this?
Thanks,
Re: 1995 Dodge Stratus Transmission filter change ? [Re: nd65] #1009928
06/09/11 11:13 AM
06/09/11 11:13 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
drop the pan, pop the filter off, ( it just snaps on )
I loosen the valve body to let it drain even more.
clean the pan lip - use black RTV to reseal the pan and refill. done
do NOT use a gasket on the pan,, it will leak .
should take maybe 5 qts to refill it
Re: 1995 Dodge Stratus Transmission filter change ? [Re: gtx6970] #1009929
06/09/11 03:11 PM
06/09/11 03:11 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Thanks a bunch gtx??
