will a Turbo melt a Glass' hood?? #1008658
06/07/11 02:59 PM
06/07/11 02:59 PM
Tuscaloosa, Alabama
speedfreak440 Offline OP
Tuscaloosa, Alabama
Got a 69 Charger I am in the process of turbocharging. Anyone have a problem with melting/setting fire to a fiberglass hood?
My glass hood is a stock-style so there's not alot of clearance, I would love to save weight but it's not too late to switch back to the steel hood before paint.
Forgot to add, this is a street car & it will see idle-time in traffic.... Gets up to 110 degrees or so here in Alabama.
Re: will a Turbo melt a Glass' hood?? [Re: speedfreak440] #1008659
06/07/11 03:38 PM
06/07/11 03:38 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
How far away is the major heat-source from the hood ?
Re: will a Turbo melt a Glass' hood?? [Re: dOc !] #1008660
06/07/11 03:42 PM
06/07/11 03:42 PM
Tuscaloosa, Alabama
Tuscaloosa, Alabama
Based on initial mock-ups I'm thinking some of the after-turbo hot piping will be around 2.5" away.
Re: will a Turbo melt a Glass' hood?? [Re: speedfreak440] #1008661
06/07/11 04:11 PM
06/07/11 04:11 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Coat it and wrap it and you will have NO worries!!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: will a Turbo melt a Glass' hood?? [Re: speedfreak440] #1008662
06/07/11 04:39 PM
06/07/11 04:39 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
2.5 inches is close ..... but in any case ... WHICHever hood you choose .... you are going to have to protect it.
Get some reflective/insulative sheeting and glue-it to the hood ...and then build a shield over that piping.
Re: will a Turbo melt a Glass' hood?? [Re: CUUDAK] #1008663
06/07/11 04:41 PM
06/07/11 04:41 PM
Tuscaloosa, Alabama
Tuscaloosa, Alabama
Will do, thanks. I was planning on coating those parts anyway just wasn't sure if it would still be too much heat. So thanks for the re-assurance.
Re: will a Turbo melt a Glass' hood?? [Re: dOc !] #1008664
06/07/11 04:44 PM
06/07/11 04:44 PM
Tuscaloosa, Alabama
Tuscaloosa, Alabama
2.5 inches is a conservative measurement (probably closer to 3.5) but I like to give myself a little bit of room for error. I will go ahead & mount a sheild/insulation as well as coating & wrapping. Thanks for the intel.
Re: will a Turbo melt a Glass' hood?? [Re: CUUDAK] #1008665
06/07/11 05:05 PM
06/07/11 05:05 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That's it!
No glove, no love.
- Stu Harmon
Re: will a Turbo melt a Glass' hood?? [Re: feets] #1008666
06/07/11 08:26 PM
06/07/11 08:26 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I had the world's crappiest hood. An "unlimited" brand. The hood would smell like fresh fiberglass on hot days cruising. During dragstrip passes it would get so soft it would look like a flag in the breeze...No joke.
I ended up making some very light, thin gauge aluminum shields mounted on the underside of the hood and it solved all the previous mentioned problems. It was very cheap, and never got in the way or complicated working on the engine in any way.
Re: will a Turbo melt a Glass' hood?? [Re: speedfreak440] #1008667
06/07/11 09:07 PM
06/07/11 09:07 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
This is what I am using,
http://cgi.ebay.com/ebaymotors/DEI-TITAN...sQ5fAccessories
I also got the high temp silicone coating and media blasted all the hotside pipe and turbine housing and shot them and cooked them per instructions. I will get them wrapped this weekend and post a pic.
Re: will a Turbo melt a Glass' hood?? [Re: feets] #1008668
06/08/11 02:12 AM
06/08/11 02:12 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
That's it!
No glove, no love.
I run that same turbo blanket and ir rests against the paint of the car with zero issues.
Re: will a Turbo melt a Glass' hood?? [Re: joshking440] #1008669
06/08/11 03:51 PM
06/08/11 03:51 PM
Tuscaloosa, Alabama
Tuscaloosa, Alabama
I actually work at a John Deere dealership & have access to industrial turbo blankets like that, I will pick one out of our parts dept. that fits my turbo pretty closely. Thanks for all of the replies, it's cool that moparts is really starting to get some turbo love!!!
Re: will a Turbo melt a Glass' hood?? [Re: speedfreak440] #1008670
06/09/11 10:54 PM
06/09/11 10:54 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Ha ha ha
Snail condoms!
I need a big one
